INSTALLING a 63-3153KT Comp Cams LS1 Adjustable Timing Set
Old 03-26-2006, 12:37 PM
MICAH HERRON's Avatar
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
Default INSTALLING a 63-3153KT Comp Cams LS1 Adjustable Timing Set
Has anyone installed this chain? If so, where did you get the tools mentioned on the below link?
http://www.compcams.com/Technical/In.../Files/175.pdf
Thanks,
Micah
Quick Reply: INSTALLING a 63-3153KT Comp Cams LS1 Adjustable Timing Set
