Removing Crank
Old 03-26-2006, 04:43 PM
pist0lpete's Avatar
Default Removing Crank
I am tearing down an LS1 to send to the machine shop and I am to the point of pulling the crank out. Is there a particular sequence in which I should loosen the main cap bolts and studs? Thanks in advance for all your help guys.
Old 03-26-2006, 04:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
just pull really hard on it...
Old 03-26-2006, 05:27 PM
pist0lpete's Avatar
Well I tried that and it didn't work. Anybody have any serious answers? lol
Old 03-26-2006, 05:30 PM
92zcamaroperson's Avatar
you have the caps off and the crank wont come off? Are you sure thatyou have all of the caps off?
Old 03-26-2006, 05:33 PM
lowyukon's Avatar
the main caps has bolts on the side of block. 10mm soket.
Old 03-26-2006, 05:34 PM
pist0lpete's Avatar
No I have just never messed with aluminum blocks before and I want to make sure not to warp the block. The caps are still bolted on. Do I need take out the bolts and studs in a certain sequence. (ie the ones on the outside first then work my way ing or something like that?)
Old 03-26-2006, 06:06 PM
indyboom's Avatar
No. its fine. Just loosen them up. Then pull them out.. But i believe you need a tool to reailine
Old 03-26-2006, 06:08 PM
pist0lpete's Avatar
K thanks for the info I will keep that tool in mind when it comes time to re-assemble.
