edelbrock cams
Old 03-27-2006, 07:53 AM
knife's Avatar
Default edelbrock cams
Are camshaft numbers 2215 & 2216 solely for use in LS1 CARBURETED engines (is it indicated in the catalog )? If so, what are the consequences to the engine of mistakenly installing one of them in a standard fuel injected LS1? Would anything carryover to the transmission or driveline?
If the camshafts can be used on the LS fuel injected setup, what would cause the engine to be rough and produce poor bottom end power? other than an improper tune.
i sent an email to edelbrock asking the same, but i have never had luck with their response time. thought maybe someone here can help.
TIA
