Anyone running the LS2 timing set? How much slack?
Old 03-29-2006, 12:45 AM
NassyVette's Avatar
Default Anyone running the LS2 timing set? How much slack?
Is anyone running the LS2 cam gear, chain and crank sprocket? If so did you have any problems with it?
My new timing set seems a little loose...but I didn't check the tension of the stocker before removing so I can't compare. Theres about 3/8" of play side to side max when applying side pressure in the middle of the chain. Is this normal...I don't really feel like changing the crank gear again just to check.
Old 03-29-2006, 09:02 AM
PREDATOR-Z's Avatar
That is good. Too tight will apply unnecessary pressure on your cam bearings,.
Old 03-29-2006, 09:13 AM
NassyVette's Avatar
Thanks predator. Hopefully I can get it fired up tonight
Old 03-29-2006, 10:21 AM
Reject's Avatar
you need to but the whole set to install it or can you just install the chain on the ls1? i'm going to start building up a small parts pile pretty soon to that's why i asked, thanks in advance
Old 03-29-2006, 10:34 AM
REDWS6ROCKET's Avatar
just the chain, sprockets the same.
Old 03-29-2006, 03:17 PM
Ωmega's Avatar
I use just the chain, it's always a little loose.
Old 03-30-2006, 09:37 AM
Reject's Avatar
alright great thanks for clearing it up for me!
Old 03-30-2006, 11:08 AM
NassyVette's Avatar
My car has 85K miles on it so I decided to swap the gears and the chain just to be safe. FWIW I noticed more wear on the crank sprocket than on the cam sprocket. The cam gears are the same except the LS2 is a solid piece.
Edit: Before anyone bitches about the coolant, the previous owner put it in.
I've got a radiator and some coil packs to install tonight and it'll be good to go.
PS I should have a sound clip up sometime soon for anyone who's interested.
Attached Thumbnails Anyone running the LS2 timing set? How much slack?-dsc01176-small-.jpg   Anyone running the LS2 timing set? How much slack?-dsc01196-small-.jpg   Anyone running the LS2 timing set? How much slack?-dsc01189-small-.jpg
Quick Reply: Anyone running the LS2 timing set? How much slack?
