Car wont start
Car wont start
just finished putting everything back together, all hoses are connected , all cables are plugged. there was a wire in back of the passenger side dead that was loose when i took of the intake manifold. pulled the passenger head but that cable didnt go anythere where. any suugestions. it just wont start. i have a brand new battery also.
There's 2 ground straps on the back of the passenger head. If they're not hooked up, that could be causing your problems. What part of Vegas are you in? I might be able to give you a hand.
If your throttle body has the cables hooked up and is closed right it could be a vacumn leak. You could spray carb cleaner or something around the intake to find the leak. Make sure all the vacumn lines are hooked up as well.
