head castings 241/853 help!!!!!!!!
Old 04-03-2006, 06:33 PM
NosFed99z28's Avatar
Default head castings 241/853 help!!!!!!!!
What is the diffrence in the 241/853 head casting can some one please help
Old 04-03-2006, 06:38 PM
Ric
Ric's Avatar
Let's see here, 853 - 241 = ummm, looks like 612!
Seriously, I believe the 241s are later model heads, and they flow better than 853s, though I dunno how much better.
Old 04-03-2006, 06:59 PM
thanks man can anyone tell me anything else about them
Old 04-03-2006, 07:52 PM
AaronR's Avatar
From what Ive been told there is little difference in flow and none when ported.
Old 04-03-2006, 07:54 PM
FUN LS1's Avatar
They same cast, just the 853 is sand cast, though , which makes the surface a little rougher, and if both heads are stock the 241s will flow better. If the heads are ported, then they perform the same.
Old 04-03-2006, 07:55 PM
Xtnct00WS6's Avatar
The main difference is in the way it's cast. The 241 has the advantage till it's ported, then it doesn't matter. This has been covered numerous times, try searching first.
Old 04-03-2006, 08:03 PM
thanks just wondering because when my car was under warranty i broke a pushrod and the dealer ship said it had a cracked head and put a new one on it well Zmoneypit just did a head and cam on my car (runs like a beast now) and i noticed the casting numbers were different thanks everyone
Old 04-03-2006, 08:09 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The castings are different, and are found on different year cars.
Old 04-04-2006, 12:04 AM
Abdullah's Avatar
couldn't be the 853 casting are premiter bolts and 241 are center bolt? or i'm mistaking?
Old 04-04-2006, 12:06 AM
camaroextra's Avatar
no the 853's were center bolts also
Old 04-04-2006, 12:11 AM
Studytime's Avatar
My 806 heads are the perimeter bolt heads. These are the '98 heads.
Ben T.
Old 04-04-2006, 09:36 AM
8GTOKLR's Avatar
the dealer will probably put 241's on. If you luck out they could put 243 LS6 heads
Old 04-04-2006, 03:55 PM
Z'mnypit's Avatar
Yeah he didnt get that lucky, The thing is the left one side a 853 & the other a 241. So he had two different ones on the car. Stupid all "stealerships"
Old 04-04-2006, 04:51 PM
Yeah i thought it was purty dumb my self but thanks everyone for the help
