pushrod size question... for tr230/236/112...
Old 04-04-2006, 01:07 AM
gEtyOPaPiOn's Avatar
Default pushrod size question... for tr230/236/112...
ok i have a stock bottom stock heads ls1 with a
thunder racing 230 236 112 cam
with 7.4 pushrods and dual springs
heads never been removed from engine
other mods include fast 90/90 setup
now for some reason there is a loud noise on the intake ....like a lifter noise or some hollow air sound ...anyone help?
Old 04-04-2006, 01:11 AM
calongo_SS's Avatar
Stock rocker arms?
Old 04-04-2006, 01:15 AM
yes ...stock rockers ..sorry
Old 04-04-2006, 01:30 AM
calongo_SS's Avatar
With stock heads and 7.4 PR's you should be ok on lifter preload...
You say the sound is coming from the intake? Not from one side of the engine or the other?
Old 04-04-2006, 01:32 AM
it sounds kinda like a suction pulsating noise and a tick tick noise
Old 04-04-2006, 09:20 AM
.hmmm...
Old 04-04-2006, 08:33 PM
anyone ? help!!
Old 04-04-2006, 09:21 PM
calongo_SS's Avatar
I'd pull the valve covers and double check that all the rockers are tight. You can also try to push on the push rods and see if one feels different than the others. It's a long shot, but you may be able to tell if a lifter is bad that way.
