Morel Lifters - Pushrod Length
Old 04-04-2006, 05:32 AM
vettenuts's Avatar
Default Morel Lifters - Pushrod Length
I measured the Morels last night with a disassembled adjustable pushrod in the pushrod cup. It appears the Morels are 0.030" longer from the tip of the roller to the pushrod cup than the stock lifters. Has anyone found an off the shelf pushrod length that provides the correct Morel preload with stock gaskets? I plan to measure this weekend, but the math is telling me I may need custom pushrods.
Old 04-04-2006, 11:06 AM
vettenuts's Avatar
Anyone running these???
Old 04-04-2006, 10:59 PM
racecar's Avatar
Yes, The pushrods were way shorter. If I remember right they were 7.050???
That is with Comp adjustable rockers and a TSP 233/239 .
Old 04-12-2006, 04:13 AM
vette.se's Avatar
TTT
want to know as well
Old 04-12-2006, 05:28 AM
Viper's Avatar
I have AFR 205's milled .018, .054 gasket , custom cam, morel lifters. After measuring I'm now running a 7.300 pushrod. Base circle same as stock.
Old 04-12-2006, 05:30 AM
vettenuts's Avatar
Well, I ended up measuring for the Crane rockers, which are adjustable so I won't be much help on the stock rockers. Just for information, the Crane pushrods for their rockers and a stock setup are 7.250". As noted above, the Morel's are about 0.030" longer from roller to pushrod cup. They also use less preload than stock. After measuring for the Crane rocker, I ordered 7.150 pushrods.
