Better head to Run w/G5x2 and 150 shot?
Old 04-05-2006, 02:37 PM
HartAttack's Avatar
Default Better head to Run w/G5x2 and 150 shot?
Hey guys,
i need your opinion here.... I am wondering what you all would suggest for a good head for spraying my car. This question could go in either the nitrous section or here...but i fell it would be better answered here.
I have this G5x2 cam 232/240 .598/.609 on a 112 Lsa. I will have all the other supporting bolt ons, as well as 30lbs injectors and 255 inline bosch pump.
The nitrous kit i have is from nitro daves outlet.
will be running the plate setup with the 150 jets in.
I am looking for heads right now. i am still not to familiar with milling and proper compresion ratios for spraying. Although i know you can spray whatever. I am just looking for something that might benifit it.
I cant go over $1300...or my wife will kill me.
I would like everyones advice here. Thanks!
I already talked to Tony Mamo and Gunner a while back, maybe they could chime in as well
thanks
-Chris
Old 04-05-2006, 02:40 PM
PREDATOR-Z's Avatar
$1300 is the determining factor here. So either PP LS2/243 heads or LS6/6.0
or TSP/PRC LS2/243
Old 04-05-2006, 07:23 PM
HartAttack's Avatar
or TSP/PRC LS2/243
I assumed PRC's and Patriots would be the competing companys in this instence. but do you have a recommendation as far as which one to run? I heard 5.3 heads are great for n2o setups? is there any truth to that? Or should i just pick up an ls6 head?
thanks
Old 04-06-2006, 08:15 PM
HartAttack's Avatar
TTT
also..would 5.3 heads with a .010 mill and 59cc chambers with 2.00 and 1.57 valves would with the X2?
Old 04-06-2006, 08:40 PM
eamador11's Avatar
or TSP/PRC LS2/243
Go patriot hands down!
