HELP! Striped cam retainer plate hole?
Old 04-05-2006, 11:15 PM
maverick18's Avatar
Default HELP! Striped cam retainer plate hole?
Just found this out when I was installing my new torquer v2. Any ideas heli- coil?
thanks, Dane
Old 04-05-2006, 11:27 PM
mr2guru's Avatar
yes helicoil.... should be easy. At least easy to get to.
Old 04-05-2006, 11:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Man, that sucks.
Old 04-06-2006, 12:33 AM
maverick18's Avatar
anyone know what size the bolt is off hand?
Old 04-06-2006, 04:55 AM
kossuth's Avatar
M8, 1.25 pitch, and about 20 mm long
Old 04-06-2006, 11:35 AM
maverick18's Avatar
Thank you!
Old 04-06-2006, 11:37 AM
SiL3NtXWS6's Avatar
did the same thing on my old motor, had to helicoil it
Old 04-06-2006, 12:58 PM
maverick18's Avatar
did it work out for you ok?
Old 04-06-2006, 01:23 PM
SiL3NtXWS6's Avatar
sure did.
Old 04-06-2006, 01:38 PM
kossuth's Avatar
The Helicoil is steel which is harder than the aluminum block. You'll be perfectly ok. I know a guy that used one on his 99 SS after he stripped a head bolt out. Still going as far as I know.
Old 04-07-2006, 12:45 AM
maverick18's Avatar
Got the kit today and it was a lot easier than I thought. Now I am just waiting on my heads to get done being ported and we will be ready to go!
Thanks guys, Dane
Old 04-07-2006, 04:54 AM
BigDaddyZ28's Avatar
Thanks guys, Dane
Where did you find your helicoil kit at? Was the price pretty reasonable for the kit?
Thanks, just wondering where to look.
Old 04-07-2006, 06:17 AM
kossuth's Avatar
You can get them at pretty much any auto parts store. Napa has them as well as your Pep Boys ect ect. They might be known by a different name in the other stores. I think Napa actually carries the Helicoil brandname. If I remember correctly being it's been awhile since I had to buy any they are alittle expensive I think for what they are($20 give or take depending) but still it beats having to throw a block out.
Old 04-07-2006, 06:25 PM
maverick18's Avatar
[QUOTE=BigDaddyZ28
Thanks, just wondering where to look. [/QUOTE]
My buddy works atAdvance Auto parts so I got the %20 discount. It was $27 and I got lke a $5 discount. Advance carries the Helicoil brand name as well.
Old 06-09-2008, 03:54 PM
PERFECT Z28's Avatar
I know this is an old thread, but I ran into a similar issue with the bolt that holds the plastic lifter tray in the block.
The torque wrench I used wasn't dailed in/calibrated correctly and stripped the block threads. (the bolt had a coil of aluminum around it's threads). Needless to say the bolt will thread down to the point of "almost" tightening, then it'll spin and repeat the same process.
My buddy said I could just use a little JB WELD on the threads of the bolt to keep it in place since its only requires 8ft/lbs of torque.
So should I buy the HELICOIL 6 x 1.0 repair kit or JB WELD it?
Please give me your input.
Thanks in advance.
Old 06-09-2008, 06:16 PM
vettenuts's Avatar
Fix it correctly and use a helicoil. Just make sure you don't get any chips in the lifter bores or oil gallery.
Old 06-10-2008, 10:16 AM
helicoil it is
Quick Reply: HELP! Striped cam retainer plate hole?
