#7 Piston Failure FIX !!!
Another old school way of protecting #7 is to have all your injectors flow tested. Put the injector with the highest flow on #7. This way it will always be the richest.
I would do this: Put the highest flow injector in #7 and then the next highest in #8. Then work my way forward using the "next" highest flow injector, and so on...
I have read the above helps normalize the back pistons due to the fact they tend to get "more" air as compared to the very front intake runners...
I've done that and this is not really a fix since since the pulse width signal is the same.
It is an intake related issue.
Cure:
Independent TBs
Better intake runner design.
Cure:
Independent TBs
Read this:
Originally Posted by FASTFATBOY
Just wanted to throw this out there..I have seen 3 LS1 cars with a random misfire on #7, one with a dead miss, with the fuel system being a "dead head" system(no return to tank)...I tore down the fuel rails on all 3 cars....all cars were FULL of trash in the rear drivers side of the rail(#7)..all 3 cars were fixed with a cleaning and clean injectors. They picked up SERIOUS amounts of power.
Maybe look at this in the future.
David
David
