how to verify number from stock cam?
Old 04-06-2006, 06:24 PM
98formulaMAH's Avatar
Default how to verify number from stock cam?
I bought a stock LS6 cam from an '02 Z06. I see the numbers on the side of the cam. How can I verify that this REALLY is the cam from that year car? Thanks
Old 04-07-2006, 12:05 AM
Cool Z's Avatar
You should find 5308 printed on the back of the cam for a 02+ LS6 cam.
Old 04-07-2006, 08:56 AM
radkon's Avatar
cam doctor will give you all the specs but it'll cost you.
Old 04-07-2006, 01:42 PM
what the hell is cam doctor? or who is it?
Old 04-08-2006, 10:43 AM
LS1TECH & Trucks Sponsor
bg-sdpc's Avatar
A cam Dr. is a device that is used to measure a camshaft. It gives you all of the lobe events. (lobe centers, lobe lift, open & close location, basically the works.)
On factory camshafts, the numbers cast into or stamped into the core is not a reliable source for determining what cam you have. Most of the time those are numbers from the core manufacturer.
Brian
Old 04-08-2006, 06:01 PM
so can i take my cam somewhere to have it measured?
Old 04-10-2006, 11:44 AM
radkon's Avatar
Look in your phone book for high perfomance engine or machine shops. Give them a call and see if they can look it over. Not everone has a cam doctor but someone in your area probably does. Should cost ya about $20 or so.
