Is it my cam or my tune??OR WHAT??
I resently installed a 224/224 567/567 114lsa cam And stageII ls6 heads.
My best before the install was 12.5 109mph 1.78 60ft. My new best is 12.0 113mph 1.85 60ft. Are these times right or is something wrong, I thought this combo would put me in the mid 11's
Well...I was gonna say you needed sticky tires but you have M/T DR. I dont know why your 60ft. would drop almost a tenth of a second. Could it be you just had a bad launch? The powr is definately there because your trap speed is up there. Im intrigued though...
Yes the car was tuned, And the reason for the 60ft drop was a stall change,(tci3500 to yank3200) I know i have to restall the convertor,But my buddy with the same setup mod for mod, Could only pull a 11.9 with his tci3500 1.69ft. I just thought we would do a lot better.
Well i would think you could pull those times with out the heads. Have seen it before. You would get alot more from those heads with a larger cam.Most of the Killer A4's at the track that are running 10's and 11's have one thing in common..4000+stalls. I would guess it to be your mods are not working well together. They just are not complementing one another,,
I read about people runnin the mti c1 hammar 222/222 .556,and thay pull low 11.s with the same stall and gears.How is this, a cam is a cam its all in the grind right.
