ls2 timing chain and arp rod bolt questions-need help asap
will the ls2 timing chain work on the stock ls1 gears or will i need to buy the new gears as well?
and what is the difference between the high performance arp rod bolts and the pro series arp rod bolts?
any help is greatly appreciatted. i forgot to order these for the cam install.
Originally Posted by BIG_MIKE2005
Yes the LS2 will work on stock LS1 gears.
I believe the pro series is supposed to be a stronger bolt for highly modified motors.
