Should I even bother? (quench)
My heads are on there way here and I'm holding off on head gaskets to check P to V and make final gasket selection based on that clearence to maximize my quench.
Well here's were I'm at;
The heads are 62cc 5.3 heads with 2.02" intake and stock dia exhaust Manley pro-flo valves. The cam is an F14 so things are going to be tight. I can get a set of stock MLS gaskets (still be checking P to V) and be ready to assemble or I can wait until I measure and then order gaskets...possibly being able to go with a thinner Cometic or Fel-Pro?
I was shooting for 11:1 CR and if I use This calculator I come up with 11.3:1 with .054" gasket. If I use This calc I get 10.8-10.9:1.
I'm not as conerned with CR as I am with quench. All these numbers look good on paper, but what is the reality of performance gains versus the extra headache I'm creating?
I'm really thinking about just getting a set of MLS gaskets and not make things more difficult than need be.
What are some opinions of the group here?
Originally Posted by TAF Motorsports
How much are your pistons out of the hole?
