Victor Jr. Intake & Big Cubes
Old 04-13-2006, 11:11 AM
Z06kern's Avatar
Default Victor Jr. Intake & Big Cubes
I have used the search and have found conflicting reports. Is the Victor Jr. intake a good option for a 400+ cube all out drag race motor? I have a set of hand ported LS6 heads. I will be port matching the heads to the intake. Seems that the short runners of the Victor would be a better choice for a high revving race motor. Any opinions?
Old 04-13-2006, 11:14 AM
383ss's Avatar
hell yes it will. where have you heard otherwise?? links?
Old 04-13-2006, 11:24 AM
Z06kern's Avatar
Well, I have heard that it needs alot of port work to flow well. I just want to make sure before I purchase one.
Old 04-13-2006, 02:12 PM
383ss's Avatar
I had not heard that. mine has no port work.
Old 04-13-2006, 04:06 PM
SStrokerAce's Avatar
How much stall you want to run? That's the key to if you use one or not.
Bret
Old 04-13-2006, 04:25 PM
Z06kern's Avatar
Well, I'm thinking 3800-4000 maybe higher, I plan on spraying 200-300 direct port shot with this intake. This motor is going in a 67 pro-street Firebird that I'm starting to build so I'm going to use 4150 stye Accufab throttlebody. At this point I'm just gathering ideas as to the setup I'm going to run.
Old 04-13-2006, 07:01 PM
DanZ28's Avatar
If you do a search, there is a link showing some pics of the vic jr being slightly offset from the head ports requiring them to be ported. I don't know if this is typical or not though.
383ss, did you gain anything on the dyno or the track over your 90/90 setup, all else being equal?
Old 04-14-2006, 07:01 AM
Mater's Avatar
does any one think it could be made to work with the l92 heads?
Old 04-14-2006, 12:33 PM
strokedls1's Avatar
It could but not worth all the time it would take. Too much grinding and porting to make it cost feasible. Better off waiting on what comes out from gm or the after market.
Old 04-14-2006, 01:26 PM
beardWS6's Avatar
I`m thinking about going to a victor. But I just got the car running with the new motor. I might wait till next year. I`m sure a sweet flowing intake will be out by then. I pray so!!
Old 04-14-2006, 04:16 PM
stevemilz's Avatar
I just sent mine out to be ported for a small inch motor.
Old 04-14-2006, 06:03 PM
theblur98ss's Avatar
Who is porting the victor jr and how much?
Old 04-14-2006, 06:12 PM
383ss's Avatar
7rwhp on the dyno, BUT I had lost a little compression in a few cylinders, mostly #7 due to a burnt piston though, so considering that I wasn't too upset. track has not shown any gain yet.
maybe porting will bring out some HP. I may look into that.
Old 04-16-2006, 01:37 PM
DanZ28's Avatar
At least you gained some. Must be true, the bigger CI works better with the Vic Jr as I lost a fair amount with my 347" and Vic Jr. It would be interesting for you to get yours ported now to see how beneficial it would be, I bet you pick up some more HP/TQ. Did yours pull harder on top?
Dan
Old 04-16-2006, 02:44 PM
383ss's Avatar
Dan
SOTP is pretty hard to tell with 550rwhp
Old 04-17-2006, 01:48 PM
DanZ28's Avatar
Dyno gragh would show it
Dan
Old 04-17-2006, 01:56 PM
Z06kern's Avatar
Somewhere in the following thread it states that the Victor only flows like 275cfm on a 310cfm head. Looks like porting it is a must if you want to see sizable gains.
https://ls1tech.com/forums/showthrea...=VICTOR+INTAKE
Old 04-17-2006, 02:24 PM
stevemilz's Avatar
My buddy works for Dart.
Old 04-17-2006, 03:04 PM
383ss's Avatar
Dan
like I said, I got 7peak rwhp. lost almost nothing down low
damn, thanks for the link.. don't know how I missed that.
Old 04-17-2006, 08:16 PM
Who is porting your heads? That might be the place to start for the intake porting.
I would start at 4000rpm stall if I was doing this intake, and the more the better really.
Bret
