Turning the stock crank .010"/.020"/etc and resizing the rods??
So, I'm wondering how many guys use their stock cranks over and turn them .010" or .020" or .030" on the rods and/or mains. Will I be safe?? Also, I'm assuming you can't "resize" the stock rods due to them being a cracked rod design. Is this correct?? So basically, if I were to turn my stock crank down and run some forged rods/pistons would I be ok to turn it 7k rpm's or more?? It would be balanced of course and built correctly. LOL
*Also, is there any disadvantage to re-using a '98 LS1 block?? Are they any different than later LS1 blocks?
**What are the power levels that stock crank/rods/pistons will sustain?? I had hear 1000rwhp on the crank and 600rwhp plus on the stock rods... true?
Thanks in advance!!
-Jeremy
Thanks in advance!!
-Jeremy
You can resize the stock rods. They sell oversize on the o.d. for the bearing. You have to hone the rod .001 to .002. Clevitie CB-1776- 10 20 30 undersize for crank. Turning your crank is not a bad idea. With ebay it makes it not worth while because you can pick a crank that is a pull out for a stroker that is standard and useable for less money than you can turn yours.
