F14 faqs
F14 faqs
Anybody have the actual lobe info of the F14 to plug into the DCR calculator?
...or anything close to it?
Its in jrp's cam guide http://ourworld.cs.com/jrp98ls1/f14.jpgWeird...I was wondering this same thing earlier,dart 225 62 cc's .040 gasket and f14 I'm trying to figure the dcr on that right now
Damn it, it does say **** (sorry Allan ) Thought I was in the Mustang forum I guess
OK, the image above does have detailed cam specs on my exact cam (F14-112)
Now I need to find the best (read easiest ) DCR calculator.
I'm running stock pistons, rods etc and 62cc heads. Gaskets will be .054", .045" or .040" depending P to V.
I know a few weeks ago I was rading all about calculating DCR, but now search only brings up a couple of posts. I have the calculator from the advanced tech section, but need to convert .050 nnumbers to .006
LS1 Tech Administrator
F-13 0.006 0.050 0.200
Intake Duration - ID_______________________ 281 230 150 F-13 INTAKE
Exhaust Duration - ED______________________ 285 232 148 F-13 EXHAUST
Lobe Center Angle - LCA (also known as LSA) 112 112 112
Intake Centerline - ICL____________________ 108 108 108
Intake Valve opens - IVO___________________ 32.5 7 -33 BTDC (- indicates ATDC)
Intake Valve closes - IVC__________________ 68.5 43 3 ABDC
Exhaust Valve Opens - EVO__________________ 78.5 52 10 BBDC
Exhaust Valve Closes - EVC_________________ 26.5 0 -42 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 116 116 116
Overlap____________________________________ 59 7 -75 degrees
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
These are taken right off the Cam Doctor so they are actual measured results.
Thank you Patrick.
Edit: that's an f13, you don't happen to have the numbers for the f14? I know they are close, but I thought they were different lobe designs???
I can not thank you enough...now I need to go help my wife clean the house for Easter, but I'll sneak some time in to run these nnumbers.
Thank you Patrick.
Thank you Patrick.
283/285 at .006 for the F14
Thank you Patrick.
Thank you Patrick.
F-14 ****?
Hmmm, I come up with 8.51DCR and 11.2 SCR with a quench of .038"using a .045 gasket 62cc heads, -.007 out of the hole, advertised duration of 283/285 @ .006
throw in a .054" gasket and the DCR drops to 8.32, but quench is .047"
I wonder how that will do on 91 octane pump gas???
I need to check the numbers and run it again later.
The tighter the quench, the more "octane resistant" you combination will be. Take my car for example: I've got 11.5:1 SCR and 8.73:1 DCR, yet I'm able to run 30 degrees of timing with 0 knock at peak power. This is with 93 octane. See, because my quench is tight (.030"), I'm better able to run lots of DCR and timing without knock.
You can make more power with less knock on 91 octane with a .032" quench and higher SCR/DCR, than a .047" quench. Been proven too many times to ignore. Quench is your friend. Compression is your friend. In your case, I would recommend a .040" gasket. You will be even more knock resistant than with the .045" gasket (even though your SCR goes up).
__________________
