any bad F14's out there?
i know the F13's have had some bad batches. but have there been any bad 14's? i actually bought my cam around the time that the F13's are being called back for. but the car is my daily Driver and i dont want to tear her apart if i aint got too..i tried calling Futral but with there new hours its hard to get ahold of them...no biggie though i always have LS1Tech!! anyhow, if you have a F14 and have seen or had your cam degrade post up....thanks
Jon
Jon
Originally Posted by SUX2BU
If you REALLY don't wanna pull the cam you can pull your intake and valley cover. You can see the first two or three lifters and lobes with a flashlight. if those look good i wouldn't worry about it.
This should take a couple hours even for a first timer.
Jon
That's what she said...
Originally Posted by ssheets
I talked to Dave at FMS today. He said that all of the bad cams have been F13s (so far). No F14s have had a problem.
Hate to hijack, but I'm running 10w-30 non-synthetic. Could I switch to 10w-40 or 20w-50 to help cut down on noise?
dont know if changing from non synthetic- synthetic will quiet it down....what kinda noise does it make? just curious b/c mine makes some noise too...alil more then valve train noise...
Jon
Jon
I won't be switching to synthetic, I'll just be getting a little thicker oil than I'm running before. It's getting pretty hot around here and I might just switch anyway.
It makes just a crap load of chattery just wierd noise. If i stick my head down beside and sorta under the car on the driver or passenger side (like where the collectors are), it is the loudest. Sometimes it does it more than other times. The sound coming from the headers makes me think it's the valves just the valves shutting lol. Everyone says LS1's start making more noise when you put headers on, but I'm at a loss with mine.
that is exactly what mine does...sometimes its more audiable then other times, but i can always hear it...i thought about the vavletrain and valves myself, but who knows...im going to change my header gaskets and bolts, then put on some katech rod bolts and see what happens...just curious, how high do you spin your motor when your racing, or just gettin on it..
Jon
Jon
Jon
One thing for sure is that if it's behaving itself and being nice and semi quiet, then I do a little 1-2-3-4 rhomp, it definatly gets louder.
What timing chain/sprockets are you running? I'm using the LS2 chain and stock sprockets. I read today that the LS1 sprockets have been known to "loosen up" the LS2 chains.
I try to shift at about 6500 or so, my shift light is set at 6400. The 10w-40 I put in on saturday seemed to help a bit, but I also tightened up my band clamps at the same time, so I dunno (me = dumbass). The "reduction in noise" is probably in my head.
Originally Posted by Wicked_Hugger99
When a cam degrades what are the first signs to look for to let you know you need to check???
pulled it out and it looked like this.
https://ls1tech.com/forums/generation-iii-internal-engine/488622-f13-carnage-pics.html
NONE. The guy who's cam i swapped out, his car was running perfect and had no noise. he just wanted to change it out cause he had bought it around the time that all the other ones had messed up.
https://ls1tech.com/forums/showthread.php?t=488622
I'm not bagging on you, but the question is specific to F14s. We know about the bad F13 run. I talked to Futral and to date, they haven't had any problems with F14s.
Do you have any information about F14s failing? If so, we (and I'm sure Alan) would like to know about it, otherwise be clear on your answer.
The title of your thread you linked to is "F13 Carnage" the question was "Are there any bad F14s out there?"
If you'll notice i quoted just one sentence from the previous guys post. I was answering that one question. And if you click on the link its pretty obvious that it was an F13.
i got a f4 from the group purchase last year and it has the fine tooling marks on it.i havent installed the cam yet and after seeing all the stuff on here im afraid to.
SSheets, even though this post is mainly asking about f14s the generally topic is still focused towards bad cams right??? SUX2BU's response to my question was helpful and got me Im not knockin you or anything, just my point of view for what its worth.
