will this cam work for me? not the newb question ;)
After thinking more and more about my 1st 2 cams, I really liked my f10 over my f13. Well Im looking at getting something new. If the F13 turns out to be part of a bad batch, then Im going to get a custom grind. I need help with the .6 and .2 specs. Id like to reach about 8.5-8.7 DCR. Im thinking 228/228 110 +0 @.050 im not sure what the lift is going to be if Im using the cam motion grind, nor do I know what to even consider.
This would more or less be a stock cam only LS6 with PRC dual springs and 3.90 gears. I really want my power under the curve to jump way up! Im not too concerened about peak numbers as I have personally felt the difference and prefer the mid range power the f10 gave me, but I want more. Given the DCP desired, I want little overlap. I hope I can tune this thing
Your input please.
Your input please.
LS1 Tech Administrator
Your DCR is going to be influenced pretty heavily by your SCR. If you're running stock LS6 chamber size, you'll probably need to go a little smaller duration on the intake lobe to get your DCR above 8.50:1.
Since the LS6 heads make good flow numbers in the .650" range, you should consider Comp LSK or XFI lobes. Both are well above .600" for smaller durations. Take my cam for example, it's a 223/227 LSK lobe, but when it's put on the Cam Doctor, it actually measures 224/228. I considered going 228/228 110LSA, but to get more DCR, I chose to go with the 224 lobe on the intake. This also makes the overlap easy to live with. I can lug my motor down to 800-900 rpm in 6th gear no problem and it make abundant power right off idle. Considering my cranking compression is 245psi that should come as no surprise. Personally, I think you should take a hard look at the Comp LSK lobes. They're pretty awesome. Thunder Racing is now having bunches of cams made with them and they're doing great!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by ninobrn99
was it hard to tune at all? Will I have to shim my PRC springs?
As far as the springs, yes, you'll want to shim them to within .050" of coil bind. That's probably going to mean a 1.740" installed height, but be sure to check it with a spring height micrometer.
__________________
