Patriot heads?
Old 04-15-2006, 10:51 AM
Cbrakllr's Avatar
Default Patriot heads?
A friend of mine has a white SS and he ordered a patriot heads/cam combo but hasnt put it on yet. I was looking at an MS3 cam (thats the cam im def. going with) and a pair of patriot stage III LS6 heads. They seem to be good heads but does anyone have them and have any input?
Old 04-15-2006, 11:58 AM
FUN LS1's Avatar
The stage III heads are for 4.125" bore aren't they? I think you want the stage II's for stock LS1 bore (3.905"). ...and there must be a thousand posts about 'em if you use the search button. Try searching Dyno Results and LS1 internal forums.
Old 04-15-2006, 05:39 PM
Cbrakllr's Avatar
Oh I dont know I was talking to some guy at Patriot and he said those heads would be good. But i dont know ill find that out. Thanks for the help.
Old 04-16-2006, 02:55 PM
Bader-X's Avatar
Default stage III fits but ...
I found a post from Gunnar from Patriot saying they do custom chambers on the stage III to fit mane bores including the stock bore so that answers that.
my question is the difference between the stage II and III only the intake valve size or do they have better porting and flow better compared to a a stage II with a same size valve and a similar cumbustion chamber? and is the intake runner size is the same?
and for a stock bottom end to have say any ported head if with the same head and cam with 23X or 22x duration as an example is it better or worse for bigger intake valves on the same heads(maybe a weight issue) valve size of 2.055 or 2.08?
Last edited by Bader-X; 04-16-2006 at 03:48 PM. Reason: found the answer to half the question
Old 04-16-2006, 04:07 PM
Firehawk441's Avatar
Stage 3 heads typically have more combustion chamber work than a stage 2
Old 04-16-2006, 04:12 PM
SVT THIS's Avatar
I've been told that the difference in patriot heads (at least the 5.3L) stages 2 and 3 is the valve size only.
The larger valves you get, the harder its going to be to fit a big cam in there.
Old 04-16-2006, 05:00 PM
Bader-X's Avatar
hmmm
but still for a stock bottom end to have say any ported head if with the same head and cam with 23X or 22x duration as an example is it better or worse for bigger intake valves on the same heads(maybe a weight issue) valve size of 2.055 or 2.08?
same cam and both stages compared is there a power difference?
so the chambers might be and might not be different (other than the valves wich will affect the chamber facing the pistin area anyway) so the intake runner size is the same in both stages?
Old 04-16-2006, 05:38 PM
austin21's Avatar
im suprised that gunner hasnt said anything to you about this yet .. you might want to try and get ahold of him .. i did a similar post like this about 3 weeks ago look it up just go to the search and put in patriot heads .. might help you out
Old 04-16-2006, 06:37 PM
calongo_SS's Avatar
2.055" valve is too big for what you're trying to do. The car will be a pig w/ the 2800 stall listed in your sig.
Old 04-16-2006, 06:53 PM
SVT THIS's Avatar
You'll have about no low end. I've seen pretty impressive numbers with stock sized valves. Impressive being 450+hp
Old 04-16-2006, 09:47 PM
Cbrakllr's Avatar
Damn thanks for all the help guys!! So My question is what heads should i go with with an MS3, 4.10's, an a NX 200 progressive shot? I dont want to buy something that I will regret later.
Old 04-16-2006, 10:32 PM
SVT THIS's Avatar
PRC CNC Ls6 heads from TSP are supposed to kick some *** with that cam. Look in the dyno section.
Old 04-17-2006, 12:08 AM
dnkynrbk's Avatar
i love my stage 3 heads 64 cc chamber block .30 over with the magice stick cam kicks magor assests
Old 04-17-2006, 08:03 AM
Gunnar@Patriot's Avatar
The stage III 5.3 heads come with a 2.055"/1.60" valves and can be used on a stock bore. Our LS6 style stage III heads come with 2.08"/1.60" valves. The CNC program on the LS6 style stage II and III is the same, but there are diferences in the way the valve bowl is blended for the larger valves. We do have customers who use a stage III heads on a stock bore motor. We have done several sets for guys like Bob at Exotic who uses them on forced induction set ups. For these we do a custom stock bore chamber that is designed for the best flow with this valve set up. For your set up the stage II heads would be the better choice.
