Texas Speed Torquer v.2 Camshaft VS FUTRAL MOTORSPORTS FM13
Old 04-16-2006, 09:38 PM
just1news6's Avatar
Default Texas Speed Torquer v.2 Camshaft VS FUTRAL MOTORSPORTS FM13
Hey i am considering both the of these cams Texas Speed Torquer v.2 Camshaft and the Futral motorsports fm 13 was wondering what peoples opiniton would be on these camshafts or which you would choose. both would be on a 112 lsa
Old 04-16-2006, 09:53 PM
JZ'sTA's Avatar
Damn thats like picking between a WS6 and a SS.
Depending on what you like is where your oponion will sway.
Both are great cams and are very similar.
Both will also make very similar power.
I personially go with the TSP Torquer 2 because TSP CS is better, and Futural CS flat out sucks.
Old 04-16-2006, 09:57 PM
just1news6's Avatar
Do you think i d have any trouble with vaccum for the brakes with this cam ?? I like the duration and where it makes power at. Thanks for the help
Old 04-16-2006, 10:38 PM
BriancWS6's Avatar
No not at all, it's not like the SBC of old.
Old 04-16-2006, 10:41 PM
SSwanner's Avatar
not to thread hijack or be dumb, but what is this CS you speek of?
Old 04-16-2006, 10:43 PM
SMDLS1's Avatar
CS=Customer Service
Old 04-16-2006, 11:09 PM
just1news6's Avatar
What lsa would yall suggest a 113 or 114 or 112
Old 04-16-2006, 11:15 PM
matts22's Avatar
What is your setup?
Auto/6-Speed?
If Auto, stall?
Gears?
How will you use it?
etc.
Old 04-16-2006, 11:57 PM
just1news6's Avatar
I am a m6 stock gears 342, mac mids x pipe Lid, no emissions, the car will see some strip use very little and is mainly a daily driver
Old 04-17-2006, 12:05 AM
cws T/A's Avatar
112 for the midrange i vote tsp t2
Old 04-17-2006, 12:57 AM
99blancoSS's Avatar
t2 112 lsa
Old 04-17-2006, 02:48 AM
Rebelord's Avatar
I vote for F13.
BTW, has everyone forgot what the search button is for?
SEARCH
Old 04-17-2006, 07:57 AM
GuitsBoy's Avatar
Ive had both cams. The f13 will be a little more docile, and a little easier on your springs. The T2 will be a little more agressive, and will wear out the springs faster on that XER lobe. The f13 will have just a touch more torque directly off idle, but everywhere above 2k or so, the torquer own it. The torquer really impressed me whith how much harder it pulls up top without forfeiting much at all down on the low end.
Old 04-17-2006, 11:25 AM
just1news6's Avatar
so how often do you think i d have to replace springs for that cam?
Old 04-17-2006, 11:39 AM
cws T/A's Avatar
tsp prc doubles 20,ooo miles
Old 04-18-2006, 12:23 PM
Slow00ls1T/a's Avatar
do you think it would be fine to run comp 918s
Old 04-18-2006, 12:26 PM
co.6z28's Avatar
no, i wouldnt
prc duals, and t2 here
Old 04-18-2006, 12:27 PM
GA/TA's Avatar
Wouldn't the F14 and the Torquer be a better comparsion. But either way i would go with the Torquer cause its on XER lobes.
Old 04-18-2006, 01:00 PM
sorry for the hijack
I thought that they are good to around 600 lift
or can you use them but the springs might not last very long
Old 04-18-2006, 01:14 PM
GuitsBoy's Avatar
I use duals as opposed to the 918's but not because of the lift, as 918's have been proven to .625. I would go with the duals for some added spring pressure which youll want since the XER lobes really snap the valves open and closed. IIRC, gold duals have about 10# more seat and 40# more open pressure than 918's, but my memory is hazy. Anyway, you can get patriot duals for pretty cheap, and they come with Ti retainers. Cant beat that bargain.
Quick Reply: Texas Speed Torquer v.2 Camshaft VS FUTRAL MOTORSPORTS FM13
