Which heads will get me to 500+ hp with my setup
I've got a 408 setup with 11.1:1 SCR with 317's,a 244/248 .635/.627 112, LS6 intake, and stock ported tb that netted me 425/445. What's gonna get me to AT LEAST 500hp while not breaking the bank? I'm leaning towards the Dart 225's but I'm really not sure that would get me there. I'm not looking to spend $3k on ETP heads, so those are out. What I'm looking for are some budget heads (hence my inclination to go with the Dart's) that I can spend $1k - $1500 on now, net some good gains, and in the future add a 90/90 when I save up some more money to better utilize the heads and boost me over the 500 mark.
I don't know if going with the DART's would take your DCR too high. You're talking about dropping 10 cc's out of the chamber and still having it run on pump gas. If it were me I would send my 317's to TEA and let them go to town.
Nate
Nate
the dart heads come std. with a 62cc chamber, and i talked to them a few weeks ago about a bigger chamber and they say that they will not be making anything with a bigger chamber unless the market requires so (which it most likely will not) the darts are a nice head and i considered them myself, but like nate said, i would take those 317s you already have, sent them off to ETP or TEA and have a bad *** port job done, and probably valvejob and maybe some 2.02/1.60 valves (i have a brand new set of those for sale btw...) and i would probably mill them a little to get the compression to 11.5-11.75:1.
i would say something like that, using the heads you already have, you could probably come out right at $1,000 and have a nice set of heads and the 500rwhp you're looking for.
Well, I would like to stay below 12:1 SCR for tune and driveability issues. If someone could figure out my DCR (and inform me how to do it in the future) that'd be a huge help as well. I can email the cam specs.
Any more info from anyone who has had some head work done by TEA or ETP?
i have ETP LS6 heads on the way for my new 346 and i expect 500+rwhp with my new solid roller. ETP does some pro stock heads so you know they have their ducks in a row. give them a call and give them the info on your short block, pistons, and gaskets and they will tell you exactly what cc chamber you'll need to get whatever CR you desire.
LS1 Tech Administrator
Asking to gain 75rwhp 317s with heads alone isn't going to happen. You're going to need more airflow coming in before the heads. A velocity-ported FAST 90/90 is a must. After that, any good quality head will help, but keep in mind, without a better intake manifold, your gains are going to be ho-hum at best. To exceed 500 rwhp on a 408 means your motor's going to need to BREATHE!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Patrick - It's an M6. I know high flowing heads are worthless without the means of getting all that air to them. I just want to get the heads done first and then work on induction.
383 - thanks for the info about the 78 vs 90, I'll keep that in mind.
I'm not sure I would have to run race fuel but the tune would certainly have to be dead on when getting that high of SCR, which I'm trying to avoid if possible. I just emailed ETP and TEA about porting my 317's. Anyone else have any input on this? If you have porting experience with either of those two I'd appreciate that info as well.
Seems the AFR 225 is a logical choice considering your goals and constraints...Seems more 402/408 builds (with M6's) are making greater than 500 RWHP than less than that figure when combined with other typical bolt-on's and of course the 225 AFR's.
Proven...stronger aftermarket casting....room to grow powerwise in the future, and while not the cheapest, it isn't the most expensive option either....especially when purchased thru one of our authorized dealers.
Am I missing something here?
Good luck either way...
Tony M.
Edit....Just re-read the original post. Seems we are a little off on price, but pay a little now or a lot more later if your utimately going to look for the most from you final combination....and we (racers) always do.
Tony M.
Tony, not gonna lie and say that the AFR 225's aren't great heads because I've definitely seen a lot of great results. However, I'm pretty sure these heads will be my last big mod on the car and I'm not looking to spend huge bucks on them. I don't go to the track because I never have time and this is a semi-daily driver. I'm just trying to squeeze a decent bit more out of my 408 before I call it quits on the big power mods with my car. I've got other financial things coming up so whichever route I go on heads (and then induction) will be my last hurrah in the hp department. I just can't afford it after this. So, I'm trying to go out with a bang (for the buck, and not from behind). It seems as though sending my 317's are the best option I've heard and looked into thus far. If I had the money, I'd be going AFR's or ETP's, but the fact of the matter is I don't. I've got around $2k max for heads and induction, so I'm trying to figure the balance between the two.
IMO, there's a 30 rwhp swing with a properly ported FAST 90/90 on a 408 vs. running a ported stock TB and LS6 intake. Heck, it was worth 28 rwhp on my 346! Click signature if you want to see the dyno sheet. You're not going to see 30 rwhp difference between a ported 317 and the best AFR 225 or ET 225/245. I'd have ET or TEA port the 317s and spend the extra cash on a ported FAST. That's the best bang for the buck IMO.
Of course, if you have the bucks, then my recommendation goes to the aftermarket castings.
__________________
