Your Thoughts on a 228/232 .588/.595 110LSA +2
Hey Guys,
I'm about ready to pull the T-ReX in favor of something a bit more street-friendly, and after a good bit of research and fooling around in the cam spreadsheet, I've come up with an XE-R "lobed" 228/232 .588/.595 110 LSA on a 108 ICL.
My goal is to significantly increase torque and power in the mid-range and reach peak power at around 6300 RPM.
The cam will be spinning under stock 853 heads and enhanced with the normal array of bolt-ons, including a ported TB, LS6 intake, Hooker LTs, 3" Mufflex Y-Pipe, cutout, and March UD pulley. The power is sent to a Moser 12-bolt housing 3.90 gears, and, occasionally, I spray a 100-150 shot.
The valve events look like this (at .006, .05, and .200, respectively)...
If my calculations are correct, my DCR should be around 8.1:1.
Any input you all have to offer would be very much appreciated. I'd hate to spend the time and money to do this swap only to discover the cam in question works horribly.
Thanks,
Josh
Code:
Intake Valve opens - IVO 30.5 6 -33.5 Intake Valve closes - IVC 66.5 42 2.5 Exhaust Valve Opens - EVO 72.5 48 8.5 Exhaust Valve Closes - EVC 28.5 4 -35.5 Exhaust Centerline - ECL 112 112 112 Overlap 59 10 -69
Thanks,
Josh
I'm no expert, this is just an observation and kind of a question...but if you are going to spray NOS, don't you want a higher LSA? Not that many people run 110 on an LS1, that's why I'm wondering.
Id go with a higher lsa and advance it more. 114 +4..... It will be better for the spray, not to mention improved idle. Honestly, its not going to make alot of difference though. You'll definitely liike the cam you have chosen over the trex for low-midrange.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
LS1 Tech Administrator
PS, don't open it up to 112LSA. Go with your first choice, it will be better. Advancing cams too far is the devil.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by cenTX-LS1
This cam is exactly what I am looking for. Patrick, how hard will this cam be to tune on a 110LSA? I wasn't really planning on switching over to SD.
Originally Posted by Patrick G
There's only 10 degrees of overlap in that cam. That's not much more than an F-13 cam on a 112 and certainly less than a G5X-3 on a 112LSA. Easy to tune!
well i am running the g5x1 which is close to what you are wanting to run 228/232 .588/.574 112+4 i wish i had gotten it on a 110 though. i really like this cam and its nice to drive everyday. good midrange power and still screams up top. yours should be more of a torque machine though good luck
Look at this Crane grind. I assume the 117 lc exhaust timing is for a defficient exhaust (stock exhaust port, mufflers/cats) and a tighter lsa version would be for a more efficient exhaust (efficient exhaust port, headers, strait pipe).
http://www.cranecams.com/index.php?s...01&lvl=2&prt=5
you can use a tight LSA on a restricted exhaust. The key to a restricted exhaust is to compensate with extra duration and keep the overlap reasonable. A free flowing exhaust allows for the use of more overlap.
Thanks so much for all of the helpful input, guys. I believe I'll give Comp a call within the next few days to get this ground.
My hope is to get a fresh dyno with the T-ReX (I don't have any numbers since the SD tune and 12-bolt), then swap the cam and see how the graphs compare.
Thanks Again!
Josh
Thanks Again!
Josh
You said it right...you are no expert. The 110LSA cam will meet his goals NA and will work great on the spray. Some of you guys focus too much on LSAs and don't look at where the valve events are happening. The 228/232 110LSA +2 cam has excellent valve events for giving high dynamic compression along with good street manners and good peak power. It will rip NA and on the gas.
