Oil pump question
Old 04-17-2006, 09:46 AM
Spinmonster's Avatar
Default Oil pump question
Anyone know what the spring and bypass valve in the oil pump assembly do? What would be the symptoms of a sticky piston in that valve not moving easy or getting stuck?
Old 04-17-2006, 12:11 PM
ROCNDAV's Avatar
I believe they act as a relief valve. When the pressure gets too high, it opens up and drops the pressure. If the piston gets stuck in the relief/bypass mode, then there is little to no pressure in the system. By shimming the spring, the assembly has more pressure because the spring is compressed due to the shims) so it helps the piston return to the closed state.
