MS3 cam is comming FEW Q's?
I have a 2000 C5 M6. I drive the car very aggresivly. Right now i have Vararam Intake, supermaxx headers, B&B cat back. Now i here that it does not make power untill 4500??Is this the case? Will i have to rap this out to 7,000RPMS to get this thing moving? I run 12:20's now and em looking for mid 11's. Im going to stick with my stock greas (342). Anything i should look out for? O ya and i will be using stock heads.
From what I've heard the MS3 makes power a bit sooner than 4500 but I would rev to at least 6800 with that cam. On TSP's site it says the cam peaks around 6400.
Originally Posted by killaz
Hmm if it peaks at 6400 why do people say to run them out to 7,000.?
Ms3!!!!!
I AM RUNNING A MS3 6SPD ALL BOLT ONS IN A '72 SS CAMARO,4:11'S NOW.I PUT ABOUT 3500 MI ON THIS SET WITH A STOCK TYPE CLUTCH & 3:08'S TIL I COULD AFFORD THE 4:11'S.IT DID FINE DROVE FINE & LAID SOME BAD STRIPES DWN.THIS CAM COMES ON ABOUT 3000 TO 3500 RPM & PULLS LIKE A BBBIIIIIGGGG DAWG IN EVERY GEAR !!!!!!REDLINE IS 6800RPM, MY SHIFT LT IS SET AT 6600RPM SO I SHIFT REAL CLOSE TO REDLINE.I DRIVE THIS CAR ALOT!IT LOPES LIKE A PRO STOCK! IT REALLY CAME ALIVE WITH THE 4:11'S THOUGH!I RUN 1800RPM AT 70MPH WITH 275/60/15'S & PULL 26MPG.CAR HAS WENT 12.5'S ON STREET TIRES WITH JUST THE CAM KIT & A MAIL ORDER TUNE!JUST FINISHED REAREND SO NEW TIMES WITH SLICKS COMING SOON!WANTSUM 410
you will really like the ms3, finally got my car done last week and had the car out all weekend long. i have touched up ls1 heads and the ms3 in an a4. car pulls so much harder then my old set up in sig. i can't wait for a full tune, you will love the cam though.
