Who else sells Melling Lifters for the LS1/6?
Who else sells Melling Lifters for the LS1/6? Part number?
I know Futral Motorsports sells the Melling Lifters for the LS1/6; however, their website isn't working, no one is answering their phones and emails are not being returned. What is the part number for these lifters?
What other vendors sell these lifters? I have a 2004 C5 with an LS6 and am getting ready to swap heads and want to change lifters while I'm in there. Thanks.
I tried to find the part number on the Melling website (http://www.melling.com Melling Tool Company, PO Box 1188, Jackson, MI 49204 517.787.8172) and I think its #22201; however, I'm still not sure. I'm hoping someone chimes in that purchased a set of these lifters to provide the right part number.
Originally Posted by 2001 Pewter WS6
So can Auto Zone...
Yeah really......it's the same lifter everyone else uses except the morel. I don't know why you would use it unless you got a good deal on them....it's identical to a stock lifter...
Eaton or Delpi. . .OEM suppliers. . . aftermarket suppliers. . . whose box are we going in. . . .
Is there a design and quality difference between the Melling and Comp Cam 850 (OEM replacement) lifters? or are they the same too? I thought I read somewhere on the forum that the design of the OEM lifter and these two aftermarket versions were different in design.
I found the Melling lifters for only $8.90 each
Last edited by Ragtop 99; 04-24-2006 at 07:37 AM. Reason: Non-sponsor contact & pricing info
Summit has 87+ hyd roller lifters for cheap. If its true that there are only two OE suppliers to all companies (except morel), then these should be either the eaton or delphi. From the low res picture, the look identical to the mellings. It may be worth looking into for that price.
