Oil Pump Port Job Gone Wrong or Not?
I just ported the exit (inlet looked very smooth) on my stock 5.3l oil pump (to help my engine and tight budget) and I smoothed out all the ridges around the oil passage as i have seen in pics of other people's posts. While i had my Dremel grinding away carefully, i nicked the inner flat surface on the egde of the pump where the inner gear rides, it took a small notch of metal out of it but did not leave any ridges on the surface that would seem to scratch the inner gear. I am being very carefull building this motor as i do not want to take any risks in the assembly if it.
If i need a new pump any suggestions on an affordable one to get?
I still would like to port my own pump to save $, any good porting tricks?
Has anyone else messed up porting their own pump and what solutions did you choose?
