Found my oil consumption problem
Old 05-08-2006, 07:31 PM
tylerdj's Avatar
Default Found my oil consumption problem
I think I figured out my oil consumption problem. I have been having to add 2 quarts about every 2 weeks on my car since the cam swap. Well I pulled one of my spark plugs out today and found oil on the thread of them. So doesn't that mean that oil is leaking past my valveseals and replacing the valve seals should fix my problem?
Old 05-08-2006, 07:43 PM
evergreen0077's Avatar
either that or rocker arm bolts not sealed good enough would be my guess
Old 05-08-2006, 07:47 PM
DaddySS's Avatar
Oil on the threads usually mean a leak outside, like valve cover gasket.
Old 05-08-2006, 09:08 PM
LS1powerhouse02's Avatar
i have been having the same problem lately. I even noticed some blue smoke coming out of my exhaust. When i changed my oil this is what i found: https://ls1tech.com/forums/generation-iii-internal-engine/502443-wtf-my-oil.html
It ended up being the little spring on the end of my valve seals. So i'm going to replace the valve seals this week and i'll see what that does. Sounds like you might have the same problem. I would change my oil and see if you find the same spring. Good luck!!
Brent
Old 05-08-2006, 10:17 PM
tylerdj's Avatar
cool man...I'll probably start diggin into the valvetrain this weekend and replace the valve seals. Let me know if that fixes your problem.
Old 05-25-2006, 10:49 PM
tylerdj's Avatar
anyone else think it's the valve seals as well? I just want to make sure before I replace them.
Old 05-29-2006, 11:37 AM
tylerdj's Avatar
does anybody know the part # for the valve seals?
Old 07-01-2006, 04:08 PM
98A4LS1's Avatar
I just changed my spark plugs today and noticed a slight amount of oil on the threads. Valve seals are 4 months old.
Quick Reply: Found my oil consumption problem
