x4 and 918s
Old 07-05-2006, 03:38 PM
Cop Car's Avatar
Default x4 and 918s
will the comp 918s be alright with the x4? i know the 918s say they are good to .600 lift and the x4 has .610 lift on the exhaust side. has anyone else here ran 918s with an x4?
Old 07-05-2006, 03:45 PM
treysoucie's Avatar
get patriot dual golds
Old 07-05-2006, 03:55 PM
1fstbird's Avatar
I thought the X4 had more lift than that. Doesnt the X3 have 610 lift
Old 07-05-2006, 04:47 PM
Mcduffys's Avatar
Comp 921's or PRC Dual Golds.
Why risk it with the 918's ?
Old 07-05-2006, 06:31 PM
nexvctm2001ss's Avatar
G5X3= 234/242 600/610
Old 07-05-2006, 08:23 PM
springpeddler's Avatar
Look at the new Crane 144833B's
Definitly will handle the lift!
Old 07-05-2006, 08:43 PM
98Z28MASS's Avatar
Def need some dual valve springs...the 918's will not handle the lift on the g5x4, you will just be begging for a valve spring to break. Go with the patriot duals, prc platinums, or the comp 921's.
Old 07-05-2006, 09:14 PM
Beast96Z's Avatar
918's wouldn't hold the X2, much less the X4.
Old 07-05-2006, 11:32 PM
Cop Car's Avatar
918s = free
ive heard that you can shim the springs and they will be fine. plus i dont want to spend 600 bucks on valve springs
Old 07-06-2006, 12:53 AM
Nate_Taufer's Avatar
Incorrect. The 918's are a lot more spring than people give them credit for. They originally were rated for .615 lift and can go even more if shimmed properly. They were down rated after comp released the 921's...probably just to sell more dual springs.
918's are a great spring in a nutshell.
Nate
Old 07-06-2006, 06:55 AM
King James's Avatar
Originally Posted by Cop Car
918s = free
PP Golds are only $250
Old 07-06-2006, 08:46 AM
marooncamaroz28's Avatar
The X4 is a .612. I'd go with Patriot Gold Dual Springs. That's my setup.
Old 07-06-2006, 10:43 AM
98Z28MASS's Avatar
exactly, PP golds are $250, and which dual valve springs are $600 BTW?
Old 07-06-2006, 11:26 AM
black01_WS6's Avatar
918s = free
I am running the 918's and have had no problems, they would be fine in your setup, especially if they are free. How many miles on them? They are a great spring, and as others have pointed out they can handle it, as they are underrated.
Old 07-06-2006, 12:30 PM
allngn_c5's Avatar
I would suggest 921's or the Patriots
Old 07-06-2006, 01:04 PM
Beast96Z's Avatar
Your also not running a cam as big as the one he wants. The specs of your cam still fall within the limits of the springs, his don't. There's no way I would run the aggressive lobes like XE-R's with a single spring. Patriot/PRC duals are far cheaper than a valve lodged in a piston head.
$250 is also a far cry from $600. Valve springs are not a place to skimp out, and using used 918's on a aggressive cam is deffinatlly asking for it.
Old 07-06-2006, 01:07 PM
Beast96Z's Avatar
Nate
Unless they've revamped, they used to wouldn't hold the X2. There were multiple dyno's of X2 cams floating the 918's. They may be a good spring, I'm not doubting that, but for an aggressive cam set-up you'd be crazy to not run a dual spring.
Old 07-06-2006, 01:38 PM
monicaz28's Avatar
I like the PRC's from Texas Speed. They're around $250 I believe and good up to a .660 lift. Of course the Patriots or 921's would also be great. Definitely don't go with the 918's though. You need a good spring for a large cam, and the 918's are a great spring, but are not made for a cam that large. If the springs are free, just sell them and buy the ones you need for your cam.
Old 07-06-2006, 06:52 PM
8banger's Avatar
The 918's were originally rated at around .620" lift....I would shim them if I were going to run them with a cam like that. I have Patriot Golds that rock...but free is awesome.
Old 07-07-2006, 09:28 AM
lt197formula's Avatar
Like what most other people in this thread have said, I would not run 918s with a cam as big as the g5x4. Its just asking for problems, just go with a good dual spring like Comp 921s or PRC dual golds and not worry about it.
