ET 215 Head/Pushrod length question
Old 07-07-2006, 09:26 PM
ceo44's Avatar
Default ET 215 Head/Pushrod length question
When I originally set these heads up, a 8.10 push rod seemed to be close if not almost perfect however, when the valves are fully seated I can move the rocker arm from side to side on the fulcrum. (I checked this shortly after shut down and when cold with the same results. Therefore, there doesn't seem to be any preload on the lifter at all. The block is a forged 347 with a ET 215's using .040 Cometics, stock lifters and stock rockers. My question is should I step up to an 8.15 to see if i can achieve atleast some preload or is this ok as is.
Old 07-08-2006, 06:27 AM
Restricted User
2001 Pewter WS6's Avatar
That is normal... If you go longer so that there is no side to side play, then the valves would most likely never close all of the way. I went through this before.
Old 07-08-2006, 08:09 AM
ceo44's Avatar
Thanks WS6, I was kind of thinking in those terms, thanks for validating that.
