need help on cam choice
im stuck between two different cams. cheatr cam, and a comp 216/220
mods are. lid, ls6intake, exhaust, ported tb
future mods are- ls6 stage II heads, stall, gears
what cam is gonna be better, and remember i want to run stock manifolds, maybe shorties. lookin for the most useable power. which should i go with
track/street.
i want the one that makes the best power on the street and at the track. i dont care if it dynos high if it doesnt perform well
i looked at the dyno for the 216/220 and looked like it increases power through 1300-6200rpms. is the cheatr cam also like this
well i meant, i want whichever one makes the most useable power throughtout the whole rpm range.
i dont want one thats only good at say 3k-6200. does that make sense. i dont really get the whole cam thing yet. still learning
basically i want the best smoggable cam(live in ca) and the best one for stock manifolds
Originally Posted by orangeapeel
It is the big lift that will cause the springs to need replacement. I would say moderate driving and the occaisional trip to the drag strip you will see around 10k out of a good set of double springs before they really start showing signs of fatigue.
If you let the car warm up properly before beating the **** out of your car yeah id say the same thing, but if you keep forgetting and starting up and goin dont expect a long life springs.
