overheat question
Old 07-10-2006, 04:25 PM
bow125106's Avatar
Default overheat question
Today I took my 2001 z28 out for a spin....Well when i was driving i noticed it was running a lil over 210..........Well came to a straight stretch and hammered down on it to pass a car and i noticed that the temp went up after i slowed back down..........was between the 210 and the next mark....Took the car home let it sit with a/c on and it was about normal (lil over 210)......
Anybody know why the temp would go up like that after accelerating.....This is a new car for me and im not use to what temp it runs
Old 07-10-2006, 04:29 PM
00454sscamaro's Avatar
with the stock cooling equipment it should hover around 210.. depends on how high above 210 its going .. and soposedly 2000 and on year f body's thermostats arent very accurate.
Old 07-10-2006, 04:30 PM
lt1formula2000's Avatar
actully 99 and up temp guages are dummy guages and should set some where right above 210 during normal operation
Old 07-10-2006, 04:32 PM
bow125106's Avatar
Default .
well it does stay around 210 but like i said, when I punched it I looked down and the temp gauge had went up between the 210 and the next mark up
Old 07-10-2006, 04:59 PM
low on coolant?
Old 07-10-2006, 05:13 PM
seawolf18's Avatar
Do you still have a front air dam? Coolant level? Any crap on the cooling fins of the radiator?
Old 07-10-2006, 06:09 PM
bow125106's Avatar
Default ,
Honestly I havent checked anything ...I was just asking thinking there might be something that stood out with the car's symptoms...I will check here shortly on the coolant level...The car is a police interceptor and I believe it has a heavy duty rad...Is this correct
Old 07-10-2006, 07:35 PM
bow125106's Avatar
Default .
ok checked the coolant level and rad and both were ok..........any other suggestions
Old 07-10-2006, 09:41 PM
take out the thermostat and see if the guage changes at all... possibly faulty. the gauge could be the whole problem with this. so id look for a better means of finding actual temp also. and see if you are actually overheating.
bow125106's Avatar
Default ..
btt............
