losing oil pressure
losing oil pressure
ok when i get into the throttle my oil pressure sometimes drops about 15 psi. is this something i should worry about? if so what do i need to do to find the cause of this
Check your oil level, if you're more then one quart low, it will do this, mine did it too. If not oil level, you could have some internal motor problems. Whats the pressure like when its at a warm idle?
