WhGaskets to run with Mahle valve relief pistons
Old 07-12-2006, 10:40 AM
seth webster's Avatar
Default WhGaskets to run with Mahle valve relief pistons
Ive got PRC LS6 heads, a T2 cam on a 112, and 4cc Mahle forged valve relief pistons, and a cometic .040 gasket. Should I get the .030 gasket or smaller gasket to get more compression for my setup or would i have to worry about PTV clearance or should I just run what i have??? Im just tryin to make as much power as possible with my setup.
Thanks
Seth
Old 07-12-2006, 11:37 AM
PREDATOR-Z's Avatar
Thanks
Seth
What is the piston/ deck position value? (in or out and how much)
What cam advance?
What bore size?
What rod size?
Head chamber CC?
