Max safe RPMs
Old 07-14-2006, 08:51 AM
1hotls1's Avatar
Default Max safe RPMs
I'm running Patriot 5.3l stage 2 heads and have been told that my car is shifting too soon. Right now, it shifts at 5900 or so and my rev limiter is set at 6300. Am I leaving a lot on the table or is this OK?
Old 07-14-2006, 09:12 AM
LS1 Sounds's Avatar
What are the specs on your cam? That will affect peak HP more than the heads will. Have you had it on a dyno yet?
Old 07-14-2006, 11:01 AM
1hotls1's Avatar
The cam is a 218/221, 526"/534", 116 LSA Lunati. The car has never been on a dyno.
Old 07-14-2006, 11:06 AM
PREDATOR-Z's Avatar
Your cam should peak in the 6200>6300 range so shifts should be in the 6500 or so, but not higher.
Old 07-14-2006, 11:27 AM
1hotls1's Avatar
Until I can get a new program, I'll just manually shift and hold the gears a little longer. I was running 12.2s last weekend in drive, so I'll see what difference it makes tonight.
Old 07-14-2006, 12:07 PM
PREDATOR-Z's Avatar
I do not recommend that. Just be patient and get it retuned.
Old 07-14-2006, 12:09 PM
LS1 Sounds's Avatar
This will not work if your rev limit is set for 6,300. I would recommend setting the rev limit for 6700-6800, and set the shift points to occur at ~6500 as Predator stated. That should be a sweet spot for your cam. Your '02 short block is fine within this RPM range, just make sure you don't lose oil pressure.
Old 07-14-2006, 12:24 PM
blkZ28spt's Avatar
Please do not do that, ever. The transmission will not like you.
That about sums it up.
Old 07-14-2006, 12:42 PM
98Grnz28's Avatar
I second that!
Old 07-14-2006, 01:02 PM
98 Silver Bullet's Avatar
Usually you want your shift points 400-600 RPM above the cams HP peak.
Old 07-14-2006, 02:14 PM
GuitsBoy's Avatar
What springs? Patriot golds I assume? Yeah, set rev limit to 6700 or 6800 and set shiftpoints at 6500.
