PTV clearance and .030 quench question
Old 07-14-2006, 12:35 PM
Stroker2112's Avatar
Default PTV clearance and .030 quench question
Predator Z and/or anyone who has experience with this setup:
I've been trying to finish the top end of my new 408, and am having some confidence issues confirming the ptv clearance . I've done the light spring and clay excercise several times, but not real confident with in my results ...
My set up is:
-15cc dished Diamond pistons
.010 out of the hole
2 degree advance (111) on a Torquer2 (.595/.598 lift @.050)
4.030in bore
4.000in stroke (6.125 rods)
62cc head chamber (ls6 243s, stock valves)
.040 Cometic head gaskets
Patriot Gold dual springs with .600 lift
With the measurements above, can I be confident in my ptv? Or should I continue to test and possible modify the hydraulic lifters to get exact reading?(not sure this is needed when using light springs)...
...I realize my quench is pretty tight at .030... so this is my concern. Reading the many other posts in LS1tech regarding this issue, it seems my setup is pretty close to other successful owners' top ends.
Old 07-14-2006, 12:37 PM
GFORCE1320's Avatar
You should be fine with the quench, what did the clay results give you?
Old 07-14-2006, 12:38 PM
Uthinkso's Avatar
6.125 stroke??? I think you meant 6.125 rods and a 4.000" stroke with 4.030 piston.
P-to-V needs to meausred for sure. What measurements are you coming up with so far?
Old 07-14-2006, 12:45 PM
Yes, 6.125 rods...4.000 stroke ...and 4.030 bore...thanks.
I'm getting imprints that measure approx .0625 (or 4/64ths) ... mostly in the exhaust valve.
Old 07-14-2006, 01:03 PM
PREDATOR-Z's Avatar
Just measure the depth in the clay from deepest imprint part to piston contact.\
IMO, you are fine.
Man that motor is gonna make sick,sick trq.
~11.49 SCR and 8.79 DCR, 93 +octane recomended.
.030 quench will be a ++
Old 07-14-2006, 01:12 PM
GFORCE1320's Avatar
.060 is my comfy zone, you'll be fine.
Old 07-14-2006, 01:25 PM
Predator Z
Thanks! Would you recommend modifying the Hydraulic lifters for complete accuracy .. or just relying on the light checker springs to do the job?...I plan to measure the clay again tonight for hopefully the last time...looking for a .080 clearance on the intake and .100 on the exhaust.
...the rest of my setup is a 90TB, LS2 intake, 44#injectors, true dual exhaust (flowmasters) with long tubed headers, ported oil pump, K&N air filter, and at some point in the future...probably a new transmission! If it makes as much torque/hp as I think it will (maybe 450-500?)...I'll need to figure out how to get it all back to the wheels on my 2000 Silverado.
Best Regards,
2112Stroker
Old 07-14-2006, 01:27 PM
Slicknic,
THanks, so your ptv clearance is .060 and you have no problems? That is good to know....
