We Should List the DCR For Popular Off the Shelf Cams
Old 07-15-2006, 09:57 PM
dug
dug's Avatar
Default We Should List the DCR For Popular Off the Shelf Cams
It would give additional info for those considering which cam to use.
Old 07-15-2006, 10:00 PM
02NBMFormula's Avatar
what exact is DCR???
Old 07-15-2006, 10:05 PM
dug
dug's Avatar
Dynamic compression ratio. It changes with different cams.
Old 07-15-2006, 10:19 PM
Gearhead1's Avatar
It sure would be an eye opener to those wanting to run big cams with stock compression.
Old 07-15-2006, 10:25 PM
MUSTANGEATER's Avatar
There are way too many variables, it'd be best to just teach everyone how to calculate it.
Old 07-15-2006, 10:29 PM
dug
dug's Avatar
Not too many variables with stock longblock.
Old 07-16-2006, 12:10 AM
Super Hulk Smash
JakeFusion's Avatar
Hmm.. if I ever want to get away from the wife long enough, I may just do it. For a beer or two of course.
Old 07-16-2006, 12:54 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That and we need an overlap chart for popular cams as well for all the "Do these lope?" questions.
Old 07-16-2006, 04:12 AM
ringram's Avatar
Still too many variables.
Depends on where you time the cam, +0, +4, +2 etc also head gasket thickness etc.
Just put the right numbers into the calculator and stop being lazy.
Old 07-16-2006, 12:57 PM
dug
dug's Avatar
I am talking about stock heads, gaskets and timing chain/gears. Most people dont want the hassle of changing heads or bother to degree the cam.
Old 07-16-2006, 01:27 PM
HeapaShifter's Avatar
Don't mean to hijack.
Where can I find the DCR calculator? Or is it just a formula?
I know the formula for overlap.
Old 07-16-2006, 02:55 PM
Beast96Z's Avatar
Here's one of the most popular. At the bottom, DO NOT add 15 to the .050" IVC. The calculator uses .006" IVC, which is usally 25*-27* bigger than the .050" IVC on a LS1 Hydraulic roller. http://www.kb-silvolite.com/calc.php?action=comp
While it would be nice to have DCR's listed for diffrent cams, I agree that there are a million variables. Even with the stock short block, you'd have up to 12 DCR's for diffrent possible cam timing and that's just with advance, not to mention diffrent LSA's. If shelf cams were just XXX size, then it would be easy, but you do have options when you order one. Advance and LSA being the big options.
Old 07-16-2006, 03:25 PM
dug
dug's Avatar
Why's everyone getting so picky? Yeah, its a rough estimate but its better than nothing. Hell, even the cams them selves have some variance. I suppose every cam has to to be measured with a cam dr.
Old 07-16-2006, 04:13 PM
Sport Side's Avatar
I was wondering that myself. Use a set formula, and variables for each cam and it should work fairly well. Completely accurate? Of course not but, isn't the comparison the main idea of this? Maybe I'm overlooking somethin? Oh yeah, who is gonna do it?
Old 07-16-2006, 06:10 PM
Beast96Z's Avatar
Why's everyone getting so picky? Yeah, its a rough estimate but its better than nothing. Hell, even the cams themselves have some variance. I suppose every cam has to to be measured with a cam dr.
Not being picky, just stating the obvious. I think it would end up causing the vendors more questions and more confusion on the consumers part. 80% of consumers that buy shelf cams don't even know what DCR is. I think a DCR sticky would be a better option. If everyone knew how to use a certain calculator, it would be gravy. When I was first learning about DCR, it took me 5 minutes to yahoo a good calculator, put in my specs, and have exact DCR for my old LT-1. Givin the proper specs, I can now answer the "what's my DCR" question for these guys in less than a minute. Why post up guesstamites when you can have a exact measurment? "Close" can be the diffrence between peak performance and detonation. Then you'll always have that guy who says, " The thread/vendor said I should have this, why are all my pitons craked?", neverminding his .030" milled heads, and 106* ICL drastically chnging the equation. I guess the reason i seem "picky" is because it's not hard to use the calculator. Hell most the time it's kinda fun to see what diffrent cam durations and ICL's will do to your motor, not to mention you learn to do it the right way. I've just never seen the reason to guess when the equation is so simple.
Old 07-16-2006, 06:44 PM
LS1 Tech Administrator
Patrick G's Avatar
LOL, at least dynamic compression is something you can calculate. Back a number of years ago, very few people knew what Stall Torque Ratio was when it came to torque converters. After Yank started publishing their STR numbers (as tested on GM's transmisison dyno), other companies started publishing their own STR numbers. Once that started, everybody wanted to buy a converter based on stall speed and STR. This was a case of too much information for too many people and it actually made selecting a converter worse than better because instead of trusting the converter manufacturers for their best recommendation based on the customer's mods, the customers became converter experts overnight (usually picking the wrong converter).
I fear with too much information (without good background as to why things work as they do), cam selection will go down the same road. The moral? When in doubt, consult an expert in the field for a cam that meets your exact needs. This will keep you from being disappointed.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-16-2006, 06:59 PM
ShevrolayZ28's Avatar
Or, like me, just copy Mamo's combo.
Old 07-16-2006, 08:06 PM
Jake the SSnake's Avatar
I've got a buddy that has been building trans & converters for about 15 years and when I say STR he looks at me like .I'm no expert ,but I've learned ALOT from this forum and I've never heard or mentioned DCR outside of ls1tech ( I hang around alot of dirt trackers and help them pick their cam & heads and dcr is never mentioned). Its great for the knowledge but "book smarts" don't get you as far as actual experience.
