Bad Lifter OR Motor is f'ed up?
Old 07-18-2006, 06:28 PM
fastGBcamaro's Avatar
Default Bad Lifter OR Motor is f'ed up?
I have been having a ticking sound for some time and thought that I had a bad lifter. I drove the car a little more but didnt beat on it and I just pulled into the driveway and I am hearing a LOUD squeaking sound. At first it sounded like my exhuast had lossened up soo bad that it was shaking and squeeking, but as I popped the hood the sound is definately coming from inside the engine. Is the the sound I would hear for a toasted lifter or is it somthing worse like a spun bearing. Oil pressure is good. Does anyone have a guess what I am in for? I will be tearing the motor down pretty soon. If it is just a toasted lifter what else could it have damaged? Im guessing maybe just the cam but I dont know.
Old 07-18-2006, 09:58 PM
ArcticZ28's Avatar
Squeaking coming from INSIDE the block or could it be coming from a pulley? That could be just coincidence as I'm not sure anything internally would squeak, but may screech if that's the sound you're talking about.
Old 07-18-2006, 10:03 PM
just1news6's Avatar
bad belt tensioners tick and squeak esp that ac compressor pully
Old 07-19-2006, 05:24 PM
Default doubt it
Well I know its not the AC pulley because I took that out of the car. Im doubtful that its a pulley at all but I will check that out before I tear into the engine.
Old 07-19-2006, 10:48 PM
ricethis98's Avatar
pull off the belt and run it for a second. if its still there its not accessory related
Old 07-20-2006, 01:47 AM
CATDIESEL's Avatar
Cut your oil filter open and check for metal pieces
Old 07-20-2006, 11:12 AM
Boostaholic's Avatar
what was your oil pressure while it was running?
Old 07-20-2006, 02:28 PM
MiaSSmaro98's Avatar
yeah i have a tick too but like they told me maintain it and drive it till it dies
Old 07-21-2006, 02:21 PM
Default oil pressure
My oil pressure while cold is about 60, when idleing warm its about 40, and when under load when warm its about 60. I have had great oil pressure this whole time which makes me believe that its just a lifter.
