View Poll Results: Did you grind the rocker bolt flush to the intake wall? Or leave it poking through?
Ground the bolt flush to the port's wall
6
42.86%
Allowed the extra bolt length to hang into the port
8
57.14%
Voters: 14. You may not vote on this poll
Rocker bolt in intake port.
Old 07-19-2006, 12:56 PM
ShevrolayZ28's Avatar
Default Rocker bolt in intake port.
I was wondereing what people do with the rocker bolt that pokes into the intake port on ported heads.
Leave it hanging into the port, or grind it flush to the intake wall?
Old 07-19-2006, 02:18 PM
Xtnct00WS6's Avatar
I cut the ends off. I used a magic marker to get an idea of where to cut and then grind from there. It took a few tries for each bolt to get it right, but I think it was worth the effort. Keep in mind the intake bolts won't be interchangable afterwards so you should number each bolt with a dremel or something like it.
Old 07-19-2006, 03:20 PM
King James's Avatar
Going for every last bit of horsepower grind them off, otherwise don't waste the time.
Old 07-19-2006, 03:50 PM
NemeSS's Avatar
they are bull nose so i doubt they cause any real restriction
Old 07-19-2006, 03:58 PM
Xtnct00WS6's Avatar
Mine stuck out about a 1/4 inch, so it's not a huge restriction but a nice free mod
Old 07-19-2006, 04:03 PM
redtail2426's Avatar
its probably worth 2 horsepower.................on a good day.
Old 07-19-2006, 04:09 PM
See5's Avatar
Just be sure to put some sealer on them cause oil will suck down the threads. More than you would ever guess.
Old 07-19-2006, 07:59 PM
1QuickT-A's Avatar
I'm not gonna grind mine off because I just don't think it would be worth the hassle, but I did get some Permatex Thread Sealant w/ Teflon..
Old 07-19-2006, 08:36 PM
Thanks for chiming in guys. If I get hung up and have nothing better to do, I will grind'em down.
Old 07-20-2006, 12:21 AM
nahasapeemapetalon's Avatar
Default Oily THreads
Yes they sure can sucka lotta oil. I have had this problem on 2 cars and i didnt do either.
I just bought a 2000t/a with heads cam...etc in sig.
Anyway he didnt put sealant on the rocker studs...the exhaust stud threads go right into the head....i was using about a quart every 5-6 hundo miles...jus got it back together.
permatex forma gasket use it!!
Old 07-20-2006, 02:08 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
There you go....
Old 07-21-2006, 09:20 PM
1CAMWNDR's Avatar
Leave it. Spend your grinder time in the bowl and throat.
Old 07-21-2006, 10:00 PM
mypoorLS1's Avatar
Sounds like he already has ported heads.
Old 07-22-2006, 08:11 AM
DaleMX's Avatar
Grind them down, it only takes 20 minutes.
