Coolant temp dummy gauge
Old 07-20-2006, 09:30 AM
11Second Club
Gauge's Avatar
Default Coolant temp dummy gauge
I know that the coolant temperature gauge in my car is basically a dummy light. I've been told that if you overheat it will jump from 210* to pegged.
1) Where is the limitation keeping it from being a fully functional gauge? The sensor? The computer? The gauge cluster?
2) Is there any way to make this fully functional without spending an arm and a leg?
3) If I were going to get a gauge pod for the A-pillar, would I be able to get an aftermarket gauge that would be fully functional? Or, would it require more than just a new gauge? Would I be able to keep the one in the stock gauge cluster at least functional at the same time?
Old 07-20-2006, 09:33 AM
RoastEmSS's Avatar
get the apillar with a water temp gauge, replace the plug with the sender that comes with the kit by the #8 cylindr and this gauge will read accurately
Old 07-20-2006, 10:14 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I do beleive it is the isntrument gauge that is dummied down. The '98s had accurate water temp guages, but reportedly, GM had some complaints and concerns from people when the temp would fluctuate with the t-stat opening and closing, so in '99-'02 essentially the gauge is only good for "cold - up to temp - overheating".
Old 07-20-2006, 11:08 AM
DONAIMIAN's Avatar
in 93-98 the gauge got the signal from the sender, and then the computer got the signal from the sender. In 99 and up the computer got the signal from the sender and then the gauge got the signal from the computer. Somewhere along the way things got screwed up and like what was said above, it reads cold, normal, and hot.
Old 07-20-2006, 12:26 PM
383ss's Avatar
the sender that comes with autometer gauges has to have an adapter to fit the plug by #8. the adapter with it will not fit.
Old 07-20-2006, 12:28 PM
RoastEmSS's Avatar
ye ai forgot about that, i had to call autometer and he told me the part numbers and ordered them from summit, i forget the numbers tho
Old 07-20-2006, 12:52 PM
11Second Club
Gauge's Avatar
So, if you get an Autometer gauge, the stocker becomes dead?
Old 07-20-2006, 02:58 PM
383ss's Avatar
no. do not remove the stock sending unit. the PCM uses it for quite a bit of stuff. the stock sending unit is right by #1 exhaust.
the plug we're referring to is by #8
Quick Reply: Coolant temp dummy gauge
