new motor coming..did i get what i needed for the install?
Old 07-20-2006, 06:34 PM
ninobrn99's Avatar
Default new motor coming..did i get what i needed for the install?
ordered a 370 from HPE. Here is what ive got on the way:
shortblock
ported & shimmed oil pump
ls2 timing chain
headgaskets
arp head studs
rear main seal gasket
new timing cover gasket
poly motor mounts
dino oil
coolant
lifters, cam, and lifter trays are fairly new in current motor
anything else you all can think of that i missed?
TIA,
Nino
Old 07-20-2006, 09:11 PM
ArcticZ28's Avatar
pushrods. assembly lube for the cam/pushrods before initial startup. and make sure they've drilled the second hole for the alternator.
Old 07-20-2006, 10:41 PM
ninobrn99's Avatar
already have PR's. ive got a full bolt-on cam only ride, but going with more cubes One of the first questions I asked was about that. They said they drill them when they get them. Ill make sure they did before they ship it though..anything else?
Old 07-20-2006, 11:06 PM
ArcticZ28's Avatar
What kinda head gaskets you using?
Old 07-20-2006, 11:11 PM
ninobrn99's Avatar
stock 6.0 liter. ill have a static of 11.1 and a dcr of 8.3 or 4..have to double check. stock ls6 heads for now I actually broke my line from the condenser to the receiver during a cam install so i still need to replace that. guess its a good thing i didnt Btw, r u Jonathan?
Old 07-20-2006, 11:13 PM
ArcticZ28's Avatar
Yep, I be him... unless it's something bad... then I'm certainly not.
Old 07-20-2006, 11:20 PM
ninobrn99's Avatar
no, i bought my lifters from ya a while back haha..just wanted to make sure.
Old 07-20-2006, 11:23 PM
ArcticZ28's Avatar
Werd, I remember Seems like you've come a long ways since then.... as have I.
Old 07-20-2006, 11:24 PM
ninobrn99's Avatar
a LONG WAY! haha...you just a bit more money to play with your 408>my 370
Old 07-20-2006, 11:28 PM
Joel_SS's Avatar
I just installed a new motor.. just from the top of my head..
Crank bolt
Intake gaskets
valve cover gaskets
oil pan gasket
front/rear crank seals
lock tite red and blue
new sprak plugs
anti seeze
ArcticZ28's Avatar
I had a 370... that blew up on the dyno. That was FUN Eventually you just get fed up with it and throw down to play with the big boys.
Old 07-20-2006, 11:31 PM
ninobrn99's Avatar
Crank bolt
Intake gaskets
valve cover gaskets
oil pan gasket
new sprak plugs
anti seeze
Crank bolt-ive had the arp one for sometime now
Intake gaskets-reuseable low wear
valve cover gaskets-same as above
oil pan gasket-same as above
front/rear crank seals-ordered already
lock tite red and blue-got plenty of blue
new sprak plugs-tr6's
anti seeze-cans of it
Old 07-20-2006, 11:33 PM
ninobrn99's Avatar
how did that happen again? ill be SOL if this one blows!
Old 07-20-2006, 11:36 PM
ArcticZ28's Avatar
Piece of a broken valve from my stocker (cam installed two teeth off) somehow made it's way into the new 370 via the intake manifold. It got lodged up in there and when i transferred it over to the new engine there was no rattling in it. Then, on the dyno when we took it to almost 7k the vacuum pulled the piece into the #8 cylinder and scarred the wall up. It was already bored .060 over so I was screwed. I salvaged what internals I could and just bit the bullet for the 408.
Old 07-20-2006, 11:39 PM
ninobrn99's Avatar
damn...sucks! im gonna try to clean and inspect everything!! my only concern is my cam. its a f13 and i dont know if its one of the bad batches. I wont know till i pull it out the motor though. gonna see what i can work out with FMS if it is messed up so I dont have to wait weeks for a replacement.
Old 07-21-2006, 06:33 AM
PREDATOR-Z's Avatar
Just make sure you install new front and rear oil diverting plug. Also double check that all dowels are installed.
Old 07-21-2006, 11:45 AM
Joel_SS's Avatar
You got your arp ASSEMBLY LUBE?
Old 07-21-2006, 11:59 AM
ninobrn99's Avatar
the oil diverting plugs come installed if i remember correctly. what are the dowels?
Joel, the studs come with the lube per HPE, so yes, I think ive got that at least i hope i do
Old 07-21-2006, 12:14 PM
PREDATOR-Z's Avatar
Dowels are the circular plugs that keep the heads in place.
Old 07-21-2006, 12:17 PM
ninobrn99's Avatar
ahh..so thats what those things are called Ill be sure to get those swapped over. how's yours doing btw? any numbers yet?
