knock knock
knock knock
i just bought a 2000 trans am and found that its knocking pretty bad. i asked a shop what it was nd they said they think its piston slap but when listening to the sound clips on the site it doesnt sound the same. its more of a knock then a slap the car only has 30000 miles on it and has been running syn since 5000 with high test its whole life... does anyone else have any guesses or know of a way to check to see if it is piston slap without tearing the engine apart?
Does it go away when the engine gets warm? The reason we have piston slap is because of the material the pistons are made out of. On cold startup, the metal is contracted, allowing greater clearances between them and the wall thus causing a slapping sound. As the engine warms, the pistons expand and it goes away.
wait! i was just reading smokin t/a's thread and it said make sure you dont miss a shift... now when driving the car i noticed whenever i floored it at the end of each gear it bounced off the rev limiter...i pluged in the hypertech he gave me and found that he had the rev limiter was set at 5800 butit was shifting at 6000... so i changed it and it doesnt bounce it shifts nicely.. could that cause damage or was i just not getting full potential out of the motor?
knock?
If it does it in rotation, when its cold and be very careful, put your hand on top of vavle cover on what side its comming from. this is just to get and idea of where its comming from. get you a set of ears and listen to the short block then the top-end. its hard to say because vibration and noise travels. probably a burnt valve thats not seated right or a spring. make sure you dont have any exhaust leaks near headers it can be misleading
I agree, an exhaust leak sounds nasty. Check to see if the knock is coming from the pan area, or up top... If it's a ticking kind of knock, check for a bent pushrod or such. It's relatively easy to pull the valve covers for the sake of your wallet and that poor car. Worth a look.
yea i tooka closer listen and i think i agree its coming from the 2nd piston on the drivers side.. im gunna open her up and see what i can find thanks for all the help..
