found a ls6 cam i havent seen before......
Old 07-25-2006, 02:27 PM
2002/Black/SS's Avatar
Default found a ls6 cam i havent seen before......
i was just about to buy a 02 ls6 cam with 204/218 when the company just added a new cam, they say its from a 01 z06 and is 207/217 with .525 lift. anyone heard of this cam? is it better? i have a turbo if that matters.........
Old 07-25-2006, 04:46 PM
Aegnor's Avatar
https://ls1tech.com/forums/showpost....87&postcount=9
The specific duration's may be off a bit (should be 204/211), but yes, they're both LS6 cams.
01 LS6 had a different cam, rated at 395HP, 02+ LS6 used the higher lift and were rated at 405HP.
Old 07-25-2006, 05:47 PM
Tripintaz's Avatar
01 LS6's were rated at 385 the cam was 204/211 with less lift then and 02+ LS6 cam but it has a 116 LSA vs the 02+ LS6 cam on a 117.5 LSA
Old 07-25-2006, 11:25 PM
so the 02+ with the higher lift is perfered? agreed?
Old 07-25-2006, 11:37 PM
Jpr5690's Avatar
why get either there are much better cams out there
Old 07-26-2006, 03:29 AM
Tripintaz's Avatar
exactly
if your going to bother to do a cam swap atleast get the cheaTR cam. idles and drives identical to stock.
Old 07-26-2006, 07:21 AM
NOBR8KSS's Avatar
207/217 .525/.525 LSA 112...I think that's the GM Hot Cam...not an LS6 cam. But it would work in an LS6.
Old 07-26-2006, 10:45 AM
Chris81's Avatar
Thats true, but maybe not for the price you can get an LS6 cam for. It cost me less than the price of a new aftermarket cam for the LS6 cam, springs, pushrods and gaskets.
Old 07-26-2006, 11:04 AM
bowtieman81's Avatar
I am pretty sure he is going turbo. LS6 cams work good for turbo.
FWIW, I chose the 02 LS6 for 2 reasons: more lift and higher LSA.
Old 07-26-2006, 12:54 PM
Ubergeist's Avatar
I am going with the LS6 cam as well. Everyone knocks it. But from what I have read on here, it performs quite well, stock reliability/idle, and is cheap.
Sounds like a no brainer.
Go with the 02 Z06 cam.
Old 07-26-2006, 12:59 PM
STRIPSTAR's Avatar
02 z06 cam is better IMO for the turbo setup.
Old 07-26-2006, 01:32 PM
2000TransAmWS6's Avatar
no, that is not the Hotcam, the Hotcam is 219/228 .525/.525 112
i agree with these other guys an '02 Z06 cam would work well with your application
Old 07-26-2006, 09:03 PM
02 ZO6 cam it is!!!! too bad theres a big backorder.......
Old 07-26-2006, 09:18 PM
Smokingss's Avatar
backordered parts are the worst, im still waiting for tools to do my cam swap to a MS3.
Perhaps look at buying a used Cam, or a crate engine takeout. I will soon be selling a cam out of a brand new '03 LS6 crate engine I bought from GM. I should have it on ebay by the end of the month.
Old 07-26-2006, 09:31 PM
Ace$nyper's Avatar
From what I've read isn't the CheaTR even better for boost then the LS6?
It's grind is very close to a the TR blower cam as well.
Old 07-26-2006, 09:46 PM
67Firebird455's Avatar
I couldn't find the 02 LS6 anywhere, went with the MTI stealth II instead, it's reverse split to avoid reversion, still .581/.581 lift and also on a 116LSA which should work perfect for a turbo application.
Old 07-26-2006, 10:09 PM
kp
kp's Avatar
I ran 9.4 @ 144 with an 01 Z06 cam - they work just fine for forced induction cars and you can run 02 Z06 valve springs and stock pushrods with no problems..
Old 07-27-2006, 01:31 AM
Chris81's Avatar
True, alot of people knocked mine until I started dragging the bigger cammed cars down the track and everyone started looking for nitrous lines.. lol
BTW, I wouldn't buy one new.. there are people here on Tech with these cams for sale for CHEAP.
