Will 5.3L heads up my hp on an LS1?
Old 07-27-2006, 06:43 AM
98formulaMAH's Avatar
Default Will 5.3L heads up my hp on an LS1?
I have an assembled set of 5.3L heads with casting number 706. Does anyone know the stock flow numbers for these? Also, will my compression ratio go up or down? will positively affect my hp?
I just really need to see how much better these heads are, and if they are worth keeping. Thanks guys.
Old 07-27-2006, 08:42 AM
Brian Tooley Racing's Avatar
The stock 5.3 heads have a 1.89 intake valve and a 3.800 bore chamber, so they have more compression but flow less air due to the much smaller valve and chamber diameter. The heads when properly ported will outflow and outpower a 5.7 head with the same treatment, but gettting the chamber correct is critical. We have a killer CNC program for those heads that gets the flow up to around 315 cfm, here is a link to the info, you can deduct $300 from the price for already having the castings. http://www.totalengineairflow.com/pr.../gmhead/gmls1/
Old 07-27-2006, 09:34 AM
wow that price is a bit high for me, even after i -$300.
Old 07-27-2006, 03:07 PM
frodo84's Avatar
Here's my free opinion.... You get what you pay for...they are a proven ported head that many people (including me) would recommend...and I went through some budget heads before I bought my TEA 1.5s...good luck.
Old 07-28-2006, 10:19 AM
anybody else?
Old 07-28-2006, 10:58 AM
GuitsBoy's Avatar
Its true, without opening up the intake valve, these heads will not net you anything, and will likely lose power. Youre probably better off selling the heads and buying a set of CNC ported ls6 heads.
Old 07-28-2006, 11:16 AM
opening up? do you mean boring out the valve hole? or porting the intake runners? or both? I have the capability to port the entire head myself, but maybe not bore it out, unless i can do it with a craftsman, hahahahaha jk
Old 07-28-2006, 11:23 AM
GuitsBoy's Avatar
Installing a larger valve, valve seat, valve job and opening up the valve throat, just to get it on par with a stock ls1 head.
Old 07-29-2006, 01:02 PM
anyone else?
Old 07-29-2006, 02:40 PM
Cop Car's Avatar
send them off to get ported
