SI007 pass Cali smog?
Old 07-27-2006, 10:34 PM
Blkdoutbird's Avatar
Default SI007 pass Cali smog?
Will a SI007 cam pass smog in cali? What other cams are out there that will other than a CheaTR,224, and smaller cams? I've done the search and I want something that is slightly different than what alot of other people in Cali are running.
Old 07-27-2006, 11:46 PM
NEVR2ND's Avatar
CheaTR is a good cam. I ran only .1 & 1 MPH slower than with my F13.
And it idles 100% better.
Old 07-28-2006, 07:24 AM
PREDATOR-Z's Avatar
To be on the safe side any cam with -6* or less overlap will pass.
Now some have passed with -4* but that is borderline and requires serious tuning.
Old 07-28-2006, 12:31 PM
8GTOKLR's Avatar
220/220
224/224 maybe on a 113 or bigger LSA
210/216
then the cheater
Here in Cali its more visual then anything else. a lot pass emmsions but not the visual
Old 07-28-2006, 01:25 PM
PREDATOR-Z's Avatar
One of my favorite all around Cali cams is the Stealth I from MTI
220/220, .581/.581 115+0 XE-R lobes.
Old 07-28-2006, 02:13 PM
gun5l1ng3r's Avatar
What about the staelth II?
Old 07-28-2006, 02:39 PM
SS4Luck's Avatar
with full bolt on and a set of heads what kinda power will that came make?
Old 07-28-2006, 03:17 PM
67Firebird455's Avatar
That's what I plan to run with the turbo setup in the new 347 I'm puttin together, we will see... The fact that it's reverse split on an even higher LSA than the stealth I gives indication that it will also be a "clean" cam. We will see!
Old 07-30-2006, 10:00 AM
how much overlap does the SI007 cam have? If I were to special order one on a 116LSA would that produce enough negative overlap to pass emissions? Also how do u calculate for overlap? What effects would less overlap cause? I would like a sleeper cam that is slightly larger than a 224, I think the CheaTR would be a great cam, just more lift than what I am looking for.I also am running a pretty free flowing exhaust that's why I am leaning more towards a reverse split cam.Also I am split between a set of PRC or PP heads.The problem is I'm not sure if I want a set of the 243's or a set of 5.3 heads.I am aiming for around 10.75 or 11-1 comp.So which heads would net me better figures with a cam like I am thinking of? ANy help is appreciated.
Old 07-30-2006, 10:42 AM
PREDATOR-Z's Avatar
224/224, .581/.581 115+0 (Comp cam XE-R lobes) with 62 cc TSP 243 casting stage 1 with 918's (tit retainers) and a Cometic .040 gasket for a 11.3 SCR and 8.5 DCR.
-6* overlap, 6600 rpm shiftpoints and a flat trq curve like you haven't seen before.
All of this being Stealth, emission passing 420+ rwhp on M6, 400+ on A4
Tuning a must and will run on 91 octane no problema.
Old 07-30-2006, 11:07 AM
GTO_Scott's Avatar
I have a custom cam for sale that was meant to pass smog 216/220 .5882/.5814 112 $250
Old 07-30-2006, 11:43 AM
YankeeVert.'s Avatar
At what RPM does this cam /head combo peak? Looks like a great combo.
Old 07-30-2006, 12:09 PM
PREDATOR-Z's Avatar
Should peak in the 6300 rpm range with a LS6 intake
Old 07-30-2006, 07:35 PM
So how do u calculate for overlap? So how would a SI007 perform on a 116 LSA? Would it produce enough neagative overlap to pass?
Old 07-31-2006, 05:41 AM
PREDATOR-Z's Avatar
(Duration intake+Duration exhaust)/2 - (2XLSA) = Overlap *
Old 07-31-2006, 06:58 AM
so the SI007 on a 115.5-116 LSA should be able to pass Cali smog because of -6 or -7* of overlap,correct? Now with the wider LSA what would that do to the performance profile of the cam? And it should have a less noticable lope to it on the wider LSA right?
Old 07-31-2006, 07:40 PM
ttt
