tr224 with LS6 springs??
Old 07-28-2006, 03:25 PM
slowrollin93's Avatar
Default tr224 with LS6 springs??
Who all is runnin the tr224 112 or 114 with ls6 springs, this is what i was planning to do till i read somewere that 918s were recomended. I know its close to the max lift of the ls6 springs, but i figured i was good. I have seen a couple people runnin it with ls6 springs and just wanted to get the go ahead on it from someone that knew there **** just to be on the safe side.
thanks
Jon
Old 07-28-2006, 03:30 PM
GR8GAME's Avatar
I would go at least 918s if I were you, I stepped it up to the patriot gold duals from the 918s on a 224/224 .581.581
Old 07-28-2006, 03:31 PM
DogNutz's Avatar
I myself would not reccomend it!
Old 07-28-2006, 06:05 PM
67Firebird455's Avatar
Get a set of patriot gold duals from Billy at TRT, $240 shipped for the complete set with titanium retainers, keepers, springs, and spring seats. That is a hell of a deal. Only good till the end of the month though so you better get em quick!
Old 07-28-2006, 08:47 PM
CW00BlackTA's Avatar
918's will work fine for that cam. If you plan to go bigger later, might as well get something better now though.
Old 07-29-2006, 05:30 PM
Moderator
davered00ss's Avatar
I'm running 918's. I would not try ls6 springs.
Old 07-30-2006, 05:45 AM
Ryan02SS's Avatar
How much does your motor mean to you? Don't skimp on cheap springs as you won't save anything in the long run when a spring lets go and your valves smack the piston and destroy it along with the head. It could also possibly hurt the cylinder liner and require a new shortblock. Spend $150 for a set of 918's and sleep well at night. JMHO
Old 07-30-2006, 06:40 AM
PREDATOR-Z's Avatar
LS6 springs will work if they are shimmed to increase their seat pressure capabilities, but that in turn reduces their lifespan.
918's are the ticket, I would not run duals with that cam of .563 lift (overkill).
Old 07-30-2006, 11:28 AM
DJB
12 Second club
DJB's Avatar
I run LS6 springs with my cam and it is 222/222 .566 lift 112 LSA.
Old 07-30-2006, 11:40 AM
Studytime's Avatar
Does it float the valves up high?
Ben T.
Old 07-30-2006, 11:48 PM
Studytime's Avatar
How are these springs set up? Did you just drop them in?
Ben T.
Old 07-31-2006, 05:37 AM
PREDATOR-Z's Avatar
That is a LPE cam and their ramp rate (agressiveness) is much lower than TR lobes.
Ramp rate affects more than lift on spring life.
Old 07-31-2006, 07:16 AM
Studytime's Avatar
The reason I was asking is because I have a 221/221 (.559) on the shelf in my closet.
Ben T.
Old 07-31-2006, 08:22 AM
GuitsBoy's Avatar
918's. It wouldnt be worth taking a chance if it were my car...
Old 07-31-2006, 03:54 PM
DJB
12 Second club
DJB's Avatar
I don't know how aggressive the ramp is but it does not float and I shift at 6500 RPM.
Old 07-31-2006, 04:59 PM
ArrestMeRed99Z28's Avatar
I'd say go for 918s. I got a brand new set for $140 shipped off of E-Bay.
