Possible Motor Trouble Help!
Ok i've posted on this before in several sections but now i have a more complete description. Recently I've been having problems with acceleration at first I thought it was my clutch but after recently I don't think so. So somtimes when i press the gas nothing happens. The car shudders, the rpms don't go up, and the car doesn't accelerate and the car sounds sort of funny then all the sudden its like it gets power again and the car starts moving. Other times the car accelerates half assed and then all the sudden it gets it's power again. And now when i'm idling the idle is really rough and the whole car shakes and the rpms are really low. Then all the sudden it evens out and the car doesn't shake anymore and the rpms go back to about 900 or so. And it just started doing this recently. I cleaned out my MAF and go the grease off the wires. I checked the codes the car was throwing and nothings was out off the ordinary I don't know what to do at all. Please help, anyone?
I had the same exact problem in my 00' T/A. Replaced the O2 sensors cuz there was a code and it took care of the problem. Be careful cleaning out the MAF. Damage those resistors in there and you might as well throw it away. Hope the O2 sensors fix your problem. I'm pretty sure it will. If it doesn't the next thing I would look at is fuel and ignition. Keep posted on how it goes.
