Cometic 4.160" Bore Head Gaskets on 4.125" Cylinder Bore?
Old 07-29-2006, 05:17 PM
Ferocity02's Avatar
Default Cometic 4.160" Bore Head Gaskets on 4.125" Cylinder Bore?
Simple question, will this be okay? I see no problem with it. I heard the gasket should be at least .01" larger in bore than the cylinder bore, but I never heard of a max limit. My SCR will be okay with this big of a gasket bore. I don't want to wait for custom gaskets to be made, so I'm trying to find premade ones that will work. The Felpro 4.135" bore ones are too thin.
Old 07-29-2006, 05:34 PM
Beast96Z's Avatar
Mike, those will be just fine. The CR diffrence won't even be noticeable.
Old 07-29-2006, 06:59 PM
Ferocity02's Avatar
What about the increased room of carbon deposits, or is that a negligable issue?
Old 07-29-2006, 10:14 PM
SLED28's Avatar
That will be fine, you can go bigger gasket bore then that and it still works
Old 07-30-2006, 01:03 AM
Nate_Taufer's Avatar
You're splitting hairs here. A 4.16 on a 4.125" bore is fine.
Nate
Quick Reply: Cometic 4.160" Bore Head Gaskets on 4.125" Cylinder Bore?
