ARP Main Studs
ARP Main Studs
Got a set of of studs, but curious if you have to modify the windage tray or such in using these. I have seen multiple applications (non-ls1) that 1. could not run a windage or 2. had to cut the hell out of it or dent it where the studs stick up. Please give me your opinions/suggestions/results in using ARP main studs. Thanks guys!
I can shift faster than you.
The windage tray works just fine with ARP main studs. You do need to enlarge a few bolt holes to allow it fit over the studs. Other than this, it works just fine. ARP includes hardware in the kit for the windage tray to be used.
Jason
Jason
Jason
Jason
